Most common style end dump trailer in Alabama ???
Discussion in 'Tanker, Bulk and Dump Trucking Forum' started by KwBulk18, Jun 14, 2019.
  1. KwBulk18
    KwBulk18 Light Load Member
    72
    17
    Jun 4, 2019
    was wondering what’s the most common style end dump in Alabama ? I was reading if you have a 6 axle combination meaning tri axle trailer + drive axle on tractor + steer axle you can gross 84000 on state highways plus a 10% allowance which will gross you out at 92400 so as long as you are 43ft long with 6 axles which is the FBF for 6 axles . So with that said in Alabama what’s THE MOST COMMON Length TRAILER ?? Common axles ?? Tri or tandem ?? and STEEL OR ALUMINUM ? Because I was told they haul a lot off dip rap down there but then some told me they use a lot of aluminum style end dumps so I’m curious what’s the most common style of trailer used in the dump game across Alabama ?
  3. haz-matguru
    haz-matguru Road Train Member
    2,934
    4,547
    Feb 18, 2012
    Bama has mullet end dumps
