Motor Mount Bolts
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Austin264, Jul 22, 2024.
  1. Austin264
    Austin264 Bobtail Member
    Jul 22, 2024
    Ok hoping to maybe get some answers here as I can not figure out why a Peterbilt 567 keeps breaking rear motor mount bolts. Truck is a 2019 Pete 567 Super tag, with a ISX12 with a 10spd Eaton ultrashift transmission. The driver side bolts have shears 3-4x and the passenger side bolts have shears once. All motor mounts have been OEM and 10.9 reverse hex head bolts.
  3. AModelCat
    164,663
    Do the new bolts just drop into place or do you have to pry on stuff to get them to line up?
    W923 and Lav-25 Thank this.
  4. Austin264
    Jul 22, 2024
    Everything has to be loosened in order to put the new bolts in as well as prying on stuff to get the bolts to go in as if the frames too narrow but once everything is in place everything is fine
    W923 Thanks this.
  5. AModelCat
    164,663
    That's likely your issue. The bolts are probably shearing off due to misalignment of the holes.
    W923 Thanks this.
  6. W923
    W923 Road Train Member
    1,419
    4,389
    Feb 28, 2022
    How are the new bolt being tightened?
    Oxbow Thanks this.
  7. Goodysnap
    Goodysnap Road Train Member
    3,771
    9,195
    Jul 12, 2017
    Rideandrepair, wore out and W923 Thank this.
