Mounting convex? Mirror in cab, passenger side?
Discussion in 'Questions From New Drivers' started by larry_minn, Apr 20, 2025.
  1. larry_minn
    larry_minn Light Load Member
    218
    218
    Nov 15, 2012
    Minnesota.
    Back doing limited driving, local after a few decades. Bought my own truck. Lots of angled railroad tracks. 45 degrees from road direction. One direction super easy to check a long way, each direction for trains. Other direction buildings blocking. Once you get clear of buildings. You can only see a hundred yards max out passenger side. Yes I should hear the horn. *but they do forget*. There are cross arms at all but 2 angled tracks I cross regularly. *those are limited use, but trains are possible, often going really slow*
    Risk is low I would not hear horn, crossing arms fail. But it happens. I tried going into oncoming lane, cut hard right, lean forward.. got few hundred yards more snap look. Before correcting hard left.
    Has anyone mounted a bike type mirror on passenger side grab bar? Might be too sharp an angle for convex mirror? So flat one? Plan to dig in junk pile I might have old bike clamp one to try.
    Of course my luck I will get a ticket for obstructed view. ;).
    Show me your fixes.
    nextgentrucker Thanks this.
  3. Diesel Dave
    9,794
    33,869
    Jan 20, 2010
    Hesperia, Ca.
    I set up myself BEFORE I get to the crossing to get a good view for the more blinded side.
    tscottme and kemosabi49 Thank this.
  4. larry_minn
    218
    218
    Nov 15, 2012
    Minnesota.
    It’s just not possible. I grew up around here. Many semi, combine train wrecks until they put lights, crossing arms. The elevator is along tracks, then few bins, then feed shed, loading dock. Earlier the other side of street a bar with smokers room outside, and shed for wood furnace, slab wood storage, and skid for snow removal, slab wood banded moving. 4x past there. No option I found gave decent view down tracks. A window +2’ behind passenger door might.
  5. Rideandrepair
    17,583
    56,953
    Aug 8, 2015
  6. gentleroger
    gentleroger Road Train Member
    8,002
    21,906
    Jun 1, 2010
    Even if you got a mirror mounted in the exact right place, it's not going to show you diddly.
    You're making a mountain out of the Marianas Trench. Do your traffic scans, and if you're really worried, windows down/radio off, then committ to crosing.
