MPG for my MBN CAT?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by SHC, May 3, 2011.
  1. SHC
    SHC Spoiled Rotten Brat O/O
    8,484
    7,047
    Feb 26, 2011
    Westville, IN
    04 WS Lowmax
    475hp w/13spd
    My mpg is right at 6.0 pulling empty dry bulk tanks. I set my cruise at 60mph (1325rpm) and run mostly flat land.
    I honestly expected better since I'm only pulling 15k behind me and I'm going slow. I know its not an aero truck at all, but the drag is still less than one with the tanks. I also know the MBN isn't the best, and to get it tuned, but funds are low right now. My question is, does this sound right? I'm thinking there may be another problem somewhere such as maybe a leaking turbo boot or the overhead might need done.
  3. SHO-TYME
    SHO-TYME Road Train Member
    3,425
    3,180
    Apr 20, 2011
    Dahlonega, GA
    Setting the cruise uses more fuel, you can see a hill, even if it's a small one and may just let the truck slow a little and pick back up, the cruise will just try to hold that speed, I haul lite loads like you and get way better fuel milage without cruise. What mufflers do you have on the truck?
  4. oneshot
    oneshot Medium Load Member
    626
    248
    Feb 28, 2009
    mississippi
    Is ur cruise set on soft or hard.If it's been a while on the overhead would'nt hurt to run it and pressure test CAC.It's alot of good info on here to get the MBN to run great.But to answer ur question, 6mpg sounds above avg for a stock MBN without any mods.
  5. Jfaulk99
    Jfaulk99 Road Train Member
    2,914
    1,652
    May 16, 2009
    Couch
    I agree, 6 sounds pretty good for a stock MBN. Gonna have to get Mr.Haney to either flash it to at least a 6NZ (or 7CZ) or better yet a PDI file.
    I'm assuming the converter(s) have fallen off already?
  6. Diesel Dave
    9,663
    32,734
    Jan 20, 2010
    Hesperia, Ca.
    I get better mileage using my cruise control but when I start climbing a hill, I set it off and run it manual.
  7. Diesel Dave
    9,663
    32,734
    Jan 20, 2010
    Hesperia, Ca.
    I run mine at 1400 rpm and run bout 58 mph and getting bout 7 to 7.5 mpg. Remember, Im in Cali and the speed limit is 55 :biggrin_25516:.
  8. SHC
    8,484
    7,047
    Feb 26, 2011
    Westville, IN
    It has 6" pipes from the Y out and free flow Donaldsons. Not sure about the cruise or overhead as I just got the truck a month ago.
    I am going to replace the cac boots and clamps then get my $ together for a 550 brake-saver 6NZ flash from Haney.
    I also have it scheduled to go into CAT friday to have the overhead ran and the CAC pressure checked :)
    I'm also thinking maybe the new tires are keeping me back. Hopefully once they wear in I can do a little better.
  9. rollin coal
    rollin coal Road Train Member
    13,620
    27,997
    Mar 29, 2008
    TN
    6.0 is excellent mpg's for a stock MBN. When I first got mine people here said i'd be lucky if I got 4.5 to 5.0 I got lucky in stock form it avgd 5.6mpg. Put a fuel temp wire on, upgraded turbo to borg warner non wastegated, and got Haney to flash it 6NZ 550hp 2300rpm braksaver. Last 120,000 miles since that 5.8 mpg admittedly tho i do have a heavy foot and could probably pick up a couple more tenths with a lighter foot. I typically cruise at either 1600 or 1700 rpms. I agree with others about cruise control, dont use it, drive by your boost gauge keeping it low and only using as much throttle as necessary getting/maintaining speed. Youll beat the cruise every time. And run the overhead every 100k miles whether its needing it or not. You never know what the visual inspection of the valvetrain while theyre in there adjusting might catch.
  10. 2time
    2time Bobtail Member
    13
    Sep 28, 2010
    I got roughly 4.9mpg out of my mbn .The type of work I do with the truck there is a lot of idle time and pto time.But I have a 02 n-14 cummins that religiously gets high 6 mpg doing the same work.about three weeks ago head gasket let go.in the mbn so after a good consultation with mr haney,I am in the process of un bridging the cat,after talking with mr haney he said that I should see a significant increase in fuel economy,after the rebuild with the new parts and reprogrammed ECM.
    I pull a bulk pneumatic as well and have been very happy if could have seen 6 mpg average,but no such luck.
    I can't wait to get it all back together to see the difference in fuel economy!!
  11. SHC
    8,484
    7,047
    Feb 26, 2011
    Westville, IN
    Thanks for the input.... guess I REALLY should have kept my old FLD as I was getting 8mpg out of it and it was paid for LOL
