Mpg in winter
Discussion in 'Flatbed Trucking Forum' started by flatbedrunner, Mar 3, 2013.
  1. flatbedrunner
    flatbedrunner Bobtail Member
    24
    4
    Jun 29, 2011
    rock falls, il
    My mpg last summer was 6.67 for a average. Last months MPG was down to 5.59. Any ideas what happened?? Everything is the same except my MPG.
  3. MJ1657
    MJ1657 Road Train Member
    7,521
    50,152
    Jan 28, 2012
    Isanti, MN
    Winter fuel, cold air, and increased idle time will easily do that.
    MNdriver Thanks this.
  4. rbrtwbstr
    rbrtwbstr Road Train Member
    3,403
    7,953
    Jul 11, 2012
    in the bush somewhere
    5.59 you are doing GREAT!. mine has gone from 5.78 in august to 4.4 in january. but i also need to run the engine at 900rpm to unlaod, which can take an hour or so,which sucks fuel
    Like MJ1657 said, winter fuel and cold air.
  5. flatbedrunner
    24
    4
    Jun 29, 2011
    rock falls, il
    Thats what everybody keeps telling me but if cold air does it. Then why do people put cold air induction on there engines to help with performance? Also what is in the winter blend that makes the fuel burn so poorly?
  6. Dieselgeek
    Dieselgeek Medium Load Member
    427
    210
    Nov 25, 2012
    Minnesota
    Winter fuel has less BTU's, so it takes more fuel to make your truck move...
    flatbedrunner and MJ1657 Thank this.
  7. MNdriver
    MNdriver Road Train Member
    7,985
    4,372
    Feb 24, 2012
    It's more winter blends than cold air. The cold air is more dense. It creates more drag on the truck.
    Just some of the reasoning's behind winter fuel mileage loss.
    MJ1657 Thanks this.
  8. MJ1657
    7,521
    50,152
    Jan 28, 2012
    Isanti, MN
    Im no expert but it has something to do with the density of cold air. Im sure someone will explain it.
    You don't notice it as much on the electronic trucks but the old mechanical pump trucks were real dogs on #1 fuel.
  9. critters
    critters <b>Late For Dinner</b>
    1,444
    2,440
    Jul 16, 2011
    traverse city,MI
    the dense winter air has the same effects as what you would refer to as burning rich,that's why in some parts of the country they have trucks set up for mountain driving the engine is timing is differently. dense air makes for a bad fuel/air mix
  10. Busy dad
    Busy dad Bobtail Member
    16
    6
    Feb 7, 2013
    winter fuel gives off less heat (btu) than summer fuel . The idea behind a cold air intake is to get the cooler ( more dense ) air to get more power, most cars get their air from under the hood where it is far hotter..Increased idle time is one of the biggest culprits , of fuel mileage decrease..
    MJ1657 Thanks this.
  11. windsmith
    windsmith Road Train Member
    7,296
    6,032
    Sep 2, 2011
    NEPA
    Better performance = more power. More power requires more fuel.
    The key is that they add cold air induction for better performance, not better fuel economy.
