MPG Question?
Discussion in 'Questions From New Drivers' started by Blaze8, Mar 3, 2010.
  1. Blaze8
    Blaze8 Bobtail Member
    36
    8
    Jan 14, 2009
    Two part question for local, city, and OTR.
    1. What technique do you use, ie... floating, double clutch, progressive shifting...to get best mpg?
    2. What speed tranny do you use?
    I use a 10 speed Eaton Fuller. I float the low gears, and double clutch high gears. I shift progressive when fully loaded, otherwise shift how the truck feels went not fully loaded. Thanx for your input
  3. red_eye
    red_eye Medium Load Member
    440
    123
    Dec 30, 2009
    belpre, ohio
    I have always had good results with keeping it in the highest gear I can.. an staying out of the fuel.. with out luggin it.. this don't apply to a down hill run though. :)
