Multiple 12v plug-in power inverters?
Discussion in 'Questions From New Drivers' started by Buckeye 'bedder, Feb 7, 2011.
  1. Buckeye 'bedder
    Buckeye 'bedder Road Train Member
    1,043
    440
    Sep 26, 2010
    Nowhere
    I have read a jillion posts about the 12 volt plug-n power inverters, but haven't seen where anyone is using more than one in their truck at the same time. Can you use more than one (on) at the same time?
  3. rocknroll nik
    rocknroll nik High Risk Load Member
    4,490
    5,770
    Oct 18, 2008
    can't read the sign
    sure I used to use two 400 watt inverters.....just plugged into different spots......I used to have a power strip hooked up to one for my tv, dvd,and converter box.
    Then I switched to an 800 watt and it ran the tv and stuff better. But now I won't take a tv out with me...just my laptop...play movies on it.....tv sucks anyway...LOL
    Buckeye 'bedder Thanks this.
  4. Buckeye 'bedder
    1,043
    440
    Sep 26, 2010
    Nowhere
    Yeah, I rarely watch TV except for college and NFL football. I can watch Netflix, Hulu, etc. on my laptop for other programming. One of those USB hdtv tv tuners may be an option also. BTW Nik, did you watch the Packers Superbowl win?
  5. rocknroll nik
    4,490
    5,770
    Oct 18, 2008
    can't read the sign
    yeah....I did....now I'll have to listen to it forever and a day up here:biggrin_2554:
  6. celticwolf
    celticwolf Road Train Member
    1,527
    642
    Oct 10, 2010
    Kittrell, NC
    I have two. The 2k inverter is for when I want to use my coffee pot, toaster or microwave. The 300 watter has my little fridge plugged into it. No need have the big power draw if it's not needed. I have a 100 watt one for when I fire up the laptop or my crockpot
    rocknroll nik Thanks this.
  7. red_eye
    red_eye Medium Load Member
    440
    123
    Dec 30, 2009
    belpre, ohio
    yep I have 3000 watt.. to run microwave, coffee pot, ect.. and a 400 watt to run printer and laptop, phone charger.. run them both at the same time.. but the 400 watt make noise on the CB.. the 3000 watt never has..
