Must have tools/parts you keep on your truck?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by irishluck09, Aug 28, 2020.
  1. irishluck09
    irishluck09 Medium Load Member
    330
    200
    Nov 24, 2019
    Thats true, but I like to save money lol If i can fix on the road or temp fix till I get home and save 100's of dollars, Im definitely doing it
  3. 650cat425
    650cat425 Road Train Member
    1,548
    11,044
    Jan 26, 2020
    Pennsyltucky
    When you put your selection of fittings together, be sure to have what you need to bypass the air drier.
    tommymonza and SmallPackage Thank this.
  4. Wespipes
    Wespipes Road Train Member
    1,037
    1,816
    Jul 14, 2019
    God i think I carry too much. I have a 210 peice socket, wrench set i carry, screw driver set, zip ties, vice clamps, air lines and fittings, 20v impact driver and drill, with drill bits, 1 of every filter on the truck, filter wrenches, 50ft airline hose to fill up the tires, Grease gun, knife of course, gallon of coolant, gallon of oil, 1-2 cans of pb blaster, and duct tape
    irishluck09 and Brettj3876 Thank this.
  5. 650cat425
    1,548
    11,044
    Jan 26, 2020
    Pennsyltucky
    We have almost the exact same stuff except for your impact driver and drill. Lol.
    Tug Toy, Brettj3876 and Wespipes Thank this.
  6. AModelCat
    166,503
    The old man ran a daycab locally. For the most part he kept a selection of air fittings, hose clamps, a gallon of oil/coolant, bottle of gear oil, spare gladhands, headlight, tail lights, marker lights, 7 way plug/receptacle, spare sight glass for the trailer hubs and some heat shrink butt connectors. Most cases he was driving past the house on the way to the mill so if something more major went, he'd just stop in mid trip, fix it and continue on. That was pretty rare though, his trucks were in better shape at 5 years old than most were at 6 months old.
  7. Wespipes
    1,037
    1,816
    Jul 14, 2019
    I love having the impact driver and drill. Had to replace my mud flap hangers last week. Made it a 10 min job. Plus the battery fits a vacuum I use to clean up the sleeper and cab carpet too
  8. REO6205
    REO6205 Road Train Member
    13,168
    60,509
    Feb 15, 2014
    California.
    Not in my neighborhood.
    ;) We carry air line splices, extra fuel filters, brake diaphragm, lights, duct tape, radiator hose, and bailing wire.
    The drivers supply their own tools but everybody carries a pretty good assortment.
    EDIT...This is the minimum equipment that we carry in each truck. The trucks are almost always back in the yard every night so there's no need to carry a lot of stuff.
    If you're away from home or out several days at once the more stuff you can carry the better off you'll be.
    Every chance you get to fix your own problems keeps your money where it belongs...in your pocket.
  9. Rideandrepair
    17,627
    57,044
    Aug 8, 2015
    Good list so far. I’d add a good set of jumper cables.Couple pairs of small flat vice grips, to pinch off an air line. Pipe wrench, pipe dope, cheater bar,extra air Compressor Govenor,( New, not cheap rebuilt) Maybe at least 6 gallons of the old Antifreeze after a coolant flush, I Keep old hoses, belts, wipers, for a while, till I buy new ones, keeping them onboard, for a while, till I replace them. And a tube of seals all, That stuff will fix a fuel leak in a jam. A separate electrical tool box, with an assortment of heat shrink connectors, sheathing, liquid tape, pigtails for lights. Some wiring. Solder iron. Silver solder. A HD bottle jack, old wheel bearings, idler pulleys, clamps, a/c fan and pressure switches, anything that’s still good after a replacement, for future diagnostics, or repair. An extra HVAC blower motor for the cab at least is nice to have, the prices on them has gone up, at Dealerships but you can find them for about half the price on line. Worth having one, it will go bad. An extra mirror, for parking at Pilot. Coveralls are nice to have, a small tarp, to lay on outside, and hand cleaner, Rucker work gloves.Safety glasses. Propane torch. pB blaster, zip ties, duct tape, hose clamps.
  10. Rideandrepair
    17,627
    57,044
    Aug 8, 2015
    An extra hub cap, seal, and oil.
    650cat425 Thanks this.
  11. Brettj3876
    Brettj3876 Road Train Member
    11,257
    54,063
    Nov 18, 2014
    Land of local
    Harbor freight 301pc tool set under the bunk in each truck. Ton of hose clamps, extra cac rubber boots, belts. Spare alt. In each truck. (Got used last year saved my butt from the hook)
    Better to be over prepared
