Must wipe dipstick when checking oil?
Discussion in 'Questions From New Drivers' started by Jdm5jdm5, May 30, 2020.
  1. Jdm5jdm5
    Jdm5jdm5 Light Load Member
    193
    60
    Apr 13, 2016
    When checking the oil, I usually wipe the dipstick and put it back in for about 5 seconds and read the dipstick
    I saw the guy i drive for pull the dipstick out, read it, then dip it back in, and read it again, without wiping it.
    Does wiping the dipstick matter? Is it more accurate one way or the other?
  3. Moose1958
    Moose1958 Road Train Member
    15,290
    33,957
    Dec 17, 2010
    Williesburg, Virignia
    This is one of these "from left field" questions I find funny. You really should have a clean dipstick clear of oil to get a good reading. The best time to check the oil is when the engine is off and cold. Still, I just always gave the dipstick a brief wipe.
  4. SmallPackage
    5,777
    18,542
    Dec 20, 2019
    Marion Texas
    I seen a guy or two in my time pull a stick on the fuel island with the engine still running. Lol!
    If you got some on the stick when idleing you now it’s got plenty of oil in it,
    but not the correct way to do it.
  5. HoneyBadger67
    2,056
    4,512
    Dec 15, 2018
    Savannah, TN
    If the truck has been sitting for a couple hours, you're probably safe with whatever reading you get just pulling and looking, but how difficult is it to wipe and check again? I sometimes wipe two pulls.
    Tb0n3, PE_T, Jdm5jdm5 and 2 others Thank this.
  6. lovesthedrive
    lovesthedrive R.I.P.
    15,953
    54,484
    Nov 11, 2008
    Sorrento Maine
    If you dont wipe the stick it will give you a false reading as the rotation of the crankshaft will splash oil onto the dipstick.
    WildTiger1990 and Jdm5jdm5 Thank this.
  7. lovesthedrive
    15,953
    54,484
    Nov 11, 2008
    Sorrento Maine
    If you cant find a rag. Presuming your wearing long pants (blue jeans) you can use your pants leg end to wipe the stick. It isnt that noticeable.
  8. Rubber duck kw
    6,092
    17,686
    Dec 9, 2017
    I wipe the dipstick on the cuff of my pants all the time, thats why they put them there.
  9. Qbf594
    Qbf594 Road Train Member
    1,642
    8,715
    Aug 15, 2019
    Southern Canadian annex, NY
    Answer my silly girl question. My international 2020 dipstick is the kind that has a 1/4 turn to lock it. If I give it that turn the oil is smeared. If I don't turn it it's not exactly all the way down.
    So I look in the morning when it's cold, wipe it off, put it back in without the twist and look again. This truck is only a baby at 92k so I only look maybe 1x a week and it never shows leakage so I'm not worried. I did top off 1 time with 1/2 a jug way back when I'd had it a month or so.
    So what's the proper procedure for my truck??
  10. AModelCat
    164,498
    Wipe and put it back in. More than once I've had the stick show more oil on the initial pull than any subsequent ones for some reason.
  11. AModelCat
    164,498
    My old Kitty has 2 seperate sets of markings. Engine off and engine low idle. Its quite common on equipment to have markings like that.
    Dave_in_AZ, Roberts450, Flint1 and 5 others Thank this.
