MX13 dyno results
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by MicksRule, Oct 6, 2022.
  1. MicksRule
    MicksRule Medium Load Member
    412
    354
    Dec 20, 2009
    Apple Valley, CA
    I'm not a heavy duty mechanic.
    I'm curious about a dyno report on a truck I'm looking to buy.
    The engine is a 2019 MX13 rated at 455 hp. I'm unsure what the rated torque is. It's also mated to a 12 speed automated and 2.64 rears.
    Max corrected hp at 1402 rpm was 363 and max corrected torque was 1365 at 1290 rpm.
    For those of you familiar with this motor and dyno numbers for it, are these numbers reasonable or should I run?
  3. AModelCat
    166,503
    75-90 hp loss through the drivetrain seems to be pretty typical in most cases from what I've experienced anyways.
  4. Another Canadian driver
    Another Canadian driver Road Train Member
    1,181
    4,266
    Nov 14, 2021
    ALBERTA
    A 20% power loss is usually noticed.
    A 500HP Volvo D13 delivers around 400HP on the ground with a 12 speed AT2612 direct drive tranny and 2.64 145/40 Meritor rear ends.
    MX13 455HP should deliver a 364HP recorded power to the ground.
    I hope this help you.
  5. MicksRule
    412
    354
    Dec 20, 2009
    Apple Valley, CA
    If 20% is a decent number, 363 should close enough considering any variables in test procedures or test equipment. Does this seem right?
  6. AModelCat
    166,503
    Back in the day my old man had his nearly brand new Series 60 on the dyno after an uprate to 500 hp. It laid down 411 hp to the rollers.
  7. MartinFromBC
    2,769
    12,485
    Oct 19, 2018
  8. spsauerland
    spsauerland Road Train Member
    4,296
    10,892
    May 31, 2010
    West Harrison, In
    Dyno seems good, what were numbers on the vitals like pressures and temps. I'd be interested in oil sample, trip report and after treatment history in ECM.
  9. MicksRule
    412
    354
    Dec 20, 2009
    Apple Valley, CA
    Pressures and temps are in the dyno report I posted. Also looks like the test was performed in 10th gear, based on speed and rpm numbers, and with older wide based tires based on service history that included presale reconditioning.
    Will an oil sample be accurate after an oil change?
    Trip report? I do have, at least, a partial ecm report that looked pretty good as far as total engine hours and fuel economy numbers go, but doesn't show any aftertreatment history in it. Is this what you're referring to? I may be able to get a complete report. Actual average speed is slightly better than 42 mph with all idle time.
    Average Speed....... 049 MPH Fuel Mileage........ 00008.13 MPG
    Total Distance...... 0434409 Mi Driving Mileage..... 00008.44 MPG
    Moving Mileage...... 00008.44 MPG
    Engine Time......... 010275:05 H:M
    Driving Time........ 008780:46 H:M Intertrip Idle Time. 001405:54 H:M
    Moving Time......... 008097:31 H:M Intertrip Idle Pct.. 013.68 %
    Total Active Time... 036593:01 H:M Short Idle Time..... 000803:17 H:M
    Short Idle Pct...... 007.81 %
    Over RPM Time....... 000001:32 H:M Extended Idle Time.. 000602:37 H:M
    Over RPM Percent.... 000.01 % Extended Idle Pct... 005.86 %
    Over Speed Time..... 000000:16 H:M Auto Fault Check.... N/A
    Over Speed Percent.. 000.00 % Possible Faults..... 000108 #
    Excess Speed Time... 000000:01 H:M Extraction Date..... N/A
    Coast Out of Gear... 000000:00 H:M User Fault Confirm.. N/A
  10. baha
    baha Road Train Member
    4,136
    2,837
    Jul 25, 2013
    ga
    Looking good if it passes the oil ail. and blow by test in hi gear it seems to be a good motor!
