My door won't lock
Discussion in 'Questions From New Drivers' started by Shortstuff09_40, May 7, 2017.
  1. Shortstuff09_40
    Shortstuff09_40 Bobtail Member
    5
    i got locked out of my freightliner cascadia and someone helped me get it open with a wire but now the door won't lock. How can I fix it so I can lock my truck up??
  3. Chinatown
    Chinatown Road Train Member
    77,847
    184,927
    Aug 28, 2011
    Henderson, NV & Orient
    Sounds like an electrical wire was pulled loose when the guy stuck a wire down inside the door.
    BigTennOTR Thanks this.
  4. Ridgeline
    22,741
    123,666
    Bring it to the dealer.
    DTP and truckertrae Thank this.
  5. thelushlarry
    thelushlarry Road Train Member
    3,023
    9,002
    Jan 9, 2012
    glasgow ky
    Look on the bright side now you will not lock yourself out again!
  6. Jumbo
    Jumbo Road Train Member
    3,669
    7,389
    Sep 4, 2009
    Appleton, Wisconsin
    It wont lock with the key?
  7. baha
    baha Road Train Member
    4,137
    2,837
    Jul 25, 2013
    ga
    Get the door panel off to look for the steel wire the unlocker pulled out of its hole that it was snapped into, a clip maybe on the inside of bottom of the door that will have to be snapped back in place?
    Grubby Thanks this.
  8. So what. 30 or 40 bolts to get into the inner door???
  9. TommyTrucker88
    TommyTrucker88 Light Load Member
    164
    135
    Nov 16, 2016
    POCONOS, PA
    Tip: keep several spare keys and tape one or attach one with buckler somewhere safe on the outside of the truck that only you know where it is in case you lock yourself out.
    Tip2: depending on the company or make model of truck I noticed a lot if keys are universal. I've heard and seen other drivers open other people's door. If you just ask around enough pple. That is if your at a truck stop in sure someone will be able help you get it opened.
    Funny short story, I thought I had a broken lock once . I called road rescue and was a bit paranoid about having my stuff jacked. I tried playing with the locking mechanism from the side of the door and got it to lock but was confused what happened. The next morning I sighed relief as I found out my binder with all my permits and inspections ... In the side door compartment was jamming the door handle so it was allways open. Haha im just glad it wasn't anything worse cause last thing I wanted was to be sitting around a truck stop not working or getting paid.
  10. Ubu
    Ubu Road Train Member
    1,252
    1,178
    Aug 25, 2012
    Rumored to be somewhere
    The linkage ether was bent or unhooked when the wire was used to unlock it.
    You will ether have to pull the door panel off and fix it yourself or take it to a shop and have them do it.
