My First Truck
Discussion in 'Freightliner Forum' started by BluefromBrownsville, Mar 19, 2012.
  1. BluefromBrownsville
    BluefromBrownsville Bobtail Member
    Brownsville,Tx
    Getting ready to buy My first truck. Looking at a Freightliner Columbia with a Detroit Engine 445 horsepower 10 gear. The truck has 650,000 miles. How much life does this engine have at this point? Whats a reasonable price? What questions should I ask? I plan to put it to use hauling frac sand. Is that enough horsepower for this type of work?
    Thanks in advance.
  3. oc83baker
    oc83baker Medium Load Member
    410
    127
    Jan 18, 2011
    all 48
    I have a 05 columbia and the manual calling for an overhaul at 750,000. Check it carefully for air leaks, chock the wheel release the brake and go under there and search for air leak, check for oil leak while you under there.
  4. oc83baker
    410
    127
    Jan 18, 2011
    all 48
    Can't give a price range without knowing the year. What year is it? Look in the truck paper and see what similar trucks selling for
  5. Cowpie1
    Cowpie1 Road Train Member
    5,569
    4,652
    Nov 25, 2008
    Kellogg, IA
    There is enough power out of that engine, the biggest issue would be what rear end ratio is tied onto that 10 speed and is it a 10 overdrive or 10 direct. With the right ratio, you can pull just about anything with 350 hp. Did that for a lot years, so 445 is enough.
    The overhead needs run right away. The bull gear should be checked. The crankshaft damper needs to be changed. And an oil sample and dyno test will give you the rest of the story on how far along that engine is. There is no hard an fast rule on when an overhaul will be needed. That depends on how it was driven and taken care of. And like oc83baker said, check for air leaks and oil leaks and electrical wiring throughout the truck and check www.truckpaper.com for average pricing on trucks with the same specs and mileage as that one.
  6. MNdriver
    MNdriver Road Train Member
    7,985
    4,372
    Feb 24, 2012
    :biggrin_25523:
    I seem to remember a castrated 350 mack did fine on the mountains out in the Rockies of Colorado and British Columbia.
  7. lovesthedrive
    lovesthedrive R.I.P.
    15,953
    54,484
    Nov 11, 2008
    Sorrento Maine
    The 650k miles means nothing with out knowledge of idle time. Idle time is going to be a kicker to how much maintenance you need to do. As above noted do the important stuff right off.
    Plan on the cost at 750k or beyond (borrowed time) that you may have a inframe and or transmission.
  8. MNdriver
    7,985
    4,372
    Feb 24, 2012
    either way,
    If the manual calls out 750,000 for a major, then consider it a priority to plan this for the near future expenses. I'd go talk to a local shop and see what needs to be done to schedule it in and how much notice so you put it on your schedule not random.
  9. Cowpie1
    5,569
    4,652
    Nov 25, 2008
    Kellogg, IA
    At least the Detroit series 60 is an easy engine to rebuild and parts are lower priced than Cat or Cummins.
