My thoughts on coax length
Discussion in 'CB Radio Forum' started by Timin770, Jul 29, 2021.
  1. Timin770
    Timin770 Road Train Member
    1,658
    1,759
    May 27, 2011
    Canton, GA
    Some say length matters, some say it doesn't.
    Why not use the formula and if the "length matters" crowd is right, you're good. If the "length doesn't matter" crowd is right, you're still good to go
    Crusader66 Thanks this.
  3. Ridgeline
    22,761
    124,312
    Outside of a possible change of phase issue, the length doesn’t matter because your losses are not noticeable.
  4. Night Stalker10
    Night Stalker10 Road Train Member
    1,699
    1,271
    Jun 26, 2017
    Since the velocity factor plays a roll in how fast your signal travels through the coax, I doubt anyone is going to notice a delay in your signal, if you cut the coax 4 ft longer than what the math calls for.
  5. craig_sez
    craig_sez Road Train Member
    5,570
    2,714
    Sep 5, 2013
    novascotia,Canada
    From what i discovered vf means squat ...Personally ill still wanna keep it high,no reason
  6. craig_sez
    5,570
    2,714
    Sep 5, 2013
    novascotia,Canada
    I have watched 1 of the 3 but decide for yourself
  7. Night Stalker10
    1,699
    1,271
    Jun 26, 2017
    I've watched all of those videos before. The first video is the best. The gentleman does a great job of explaining the theory as well as the visual of a matching device and coax. I've always heard that the VF in coax that's 20 feet or less, like in a mobile installation, isn't a big factor to worry about as far as HF goes.
  8. jessejamesdallas
    1,416
    855
    Oct 3, 2008
    Republic of Texas
    all coax has a resistance factor...more coax, more resistance....IMO "less resistance" would be best, meaning not to use anymore coax than you have to, to get from A to B...
    Now if your setting up some sort of beam-type array, "THEN" coax length matters because you maybe wanting the signal to hit one antenna a spit-second before it hits the other to get the results your looking for...But just one antenna?...short as possible...if co-phase, both coax runs need to be same length to where they connect back together.
    end of story....jumper lengths? IMO, same thing applies...I've not once ever blown a amp or had issues with different jumper lengths...
    however..."Opinions are like A-holes...everyone has one":D
  9. Powder Joints
    8,032
    8,496
    Sep 25, 2007
    Rosamond, SoCal
    I agree, shorter the better, even setting repeaters on the hiltops, the jumper typically does not matter as far a length. On the mobile short as practicle, maening leave enough for future repairs and snip the rest of, and dont make a coil where its all running the same direction, unless you just want to have a balun under your carpet.
  10. mike5511
    mike5511 Road Train Member
    3,157
    1,547
    May 15, 2011
    NW Arkansas
    This was a timely thread! Gonna try to get antenna installed in the truck tomorrow. Not to happy with the Hustler SSM2 ball mount I bought. It is stainless steel, but it is pretty light weight and THE DARN THINK FILLED WITH WATER WHEN IT RAINED! I ain't happy!
  11. craig_sez
    5,570
    2,714
    Sep 5, 2013
    novascotia,Canada
    Well...Use a lil silicone or coax tape and make it water tight..
