My volvo not doing auto regen
Discussion in 'Volvo Forum' started by Badesha29, Feb 22, 2021.
  1. Badesha29
    Badesha29 Bobtail Member
    My volvo not doing auto regen have to do it manually every 5k miles anyone know which sencer active auto regen so I can replace it
  3. 6cuda6
    6cuda6 Light Load Member
    259
    176
    Oct 9, 2020
    First off how do you drive the truck? Light loads, heavy loads, lots of idling, no idling, what kind of fuel, if your using bio-diesel whats the percentage, city only, flat highway, hills etc...lots of things have to be correct for the system to auto regen.....there is no such "auto regen sensor" sorry, only differential pressure sensors and temperature sensors that tell the system it needs and can auto regen.
    86scotty Thanks this.
  4. Desiaman
    Desiaman Bobtail Member
    Jul 1, 2019
    Where is the egt located on a 2013 d13 engine?
    thank you in advance.
    6cuda6 Thanks this.
  5. 6cuda6
    259
    176
    Oct 9, 2020
    There will be a sensor going into the DPF [so see the next message] and one in the exhaust tube leaving the DPF
    Desiaman Thanks this.
  6. loudtom
    loudtom Road Train Member
    1,717
    2,805
    Aug 26, 2016
    Isn't that located on the pipe between the turbo and the DPF?
  7. Desiaman
    Jul 1, 2019
    There are 2 temperature sensors, the EGT I believe is the top one in the exhaust pipe before the DPF but wasn’t sure. I’ll open it up and do some testing.
    thank you for the info.
