N-14 Freightliner no high idle
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by olpa77, May 21, 2020.
  1. olpa77
    olpa77 Light Load Member
    72
    15
    Apr 9, 2011
    Hey folks have another head scratcher for ya'll. I'm working with a 96 Freightliner FLD Cummins N-14 Celect. When parked the High Idle (pto idle) wont increase the RPM's. This truck used to be able to bump the idle up to 900 RPM's while parked. It used to work regardless of the parking brake set or released. However if you roll / coast the truck slow (walking speed) the High idle will work but as soon as the wheels stop the idle drops back down. Even if you put it in 1st gear and slow roll you can hit the cruse and idle it up to 900 RPM's. Throw it in neutral the rpm stay at 900 until the wheels stop moving then drops back down to a low idle. Cruse control works fine. Clutch switch and brake pedal will knock the cruse off so I assume they are working. ECM checks out okay as well. To say the least I am puzzled and came to you folks for help. Hopefully there is someone out there who has experienced this before that can point me to the right direction.
  3. SmallPackage
    5,818
    18,640
    Dec 20, 2019
    Marion Texas
    Speed sensor on transmission. Possibly.
    olpa77 and Rideandrepair Thank this.
  4. Final Drive
    Final Drive Road Train Member
    1,573
    2,505
    Jan 21, 2015
    Check trailer brake handle if it's slightly applied high idle won't work..
  5. olpa77
    72
    15
    Apr 9, 2011
    I think your right on the money. Thanks for your help. I was thinking no way it's the speed sensor because cruise works and the speedo works. However I finally got a code pulled from it and it's showing 241 Vehicle Speed Sensor.
    SmallPackage Thanks this.
  6. Rocketman 39470
    Rocketman 39470 Bobtail Member
    Jan 18, 2018
    I finally solved my non working high idle issue after weeks and weeks of research. I changed all the air switches and the vehicle speed sensor on my 1998 FLD 120 with the 12.7 Detroit with no help. What I finally determined was that the high idle circuit passes through the hood tilt switch and is disabled when the hood is opened. If that switch is bad or the wiring to the switch is bad and that circuit is open, your high idle will not work even though your cruise control will not be affected. I was able to bypass my hood tilt switch by unplugging it from the harness and used a large paper clip as a jumper to close the circuit. My high idle started working immediately. Hopes this will help someone with this same issue.
    Speedy356 and SmallPackage Thank this.
  7. SmallPackage
    5,818
    18,640
    Dec 20, 2019
    Marion Texas
    Never heard of a hood tilt switch. Sounds like a dumb idea. Lol.
  8. Rocketman 39470
    Jan 18, 2018
    It’s a small square box mounted inside the hood near the drivers side headlight box and plugs into the harness that tells the ecm the hood is open, therefore disabling the high idle feature of the cruise control system.
  9. IH9300SBA
    IH9300SBA Road Train Member
    2,433
    24,005
    Feb 26, 2021
    It was used so truck wouldn't start via Opt-Idle if hood was open.
