N,C dmv brake test question
Discussion in 'Questions From New Drivers' started by ridinbikes247, Apr 5, 2013.
  1. ridinbikes247
    ridinbikes247 Bobtail Member
    27
    Mar 20, 2013
    High Point N,C
    Does it matter what order the brake checks are done in. Ive heard test trailor and tractor brakes first and test leakage and warning light, and spring brakes 2nd......ive also heard to test my leakage, buzzer/spring brakes before i attempt to move thr vehicle to test for tractor and trailer supply...testing at charlotte. Any N,C drivers know ? Proper order or will it matter ? As long as i tell inspector what im doing
  3. Numb
    Numb Crusty Curmudgeon
    4,359
    10,372
    Jan 30, 2012
    Charlotte, N.Carolina
    can't remember that far back and it probably is different, but GOOD LUCK !!!!!!!!!
  4. BrianE
    BrianE Light Load Member
    164
    79
    Mar 9, 2013
    Livingston Texas
    Search youtube. There is at least one video that I know of that covers it step by step. I'd post the link but I don't think the company that posted it should get the free advertisement.
  5. CondoCruiser
    CondoCruiser The Legend
    19,726
    18,734
    Apr 18, 2010
    Tennessee
    A pti doesn't have to be in any certain order. It just has to be completed. It's just taught that way in sequence because it's more efficient and easier to remember. The inspector is looking to see you know what you are talking about. Once you get outside the cab you won't actually do a pti but tell him what you would look at and what for. Just point at everything and say you look for it being cracked or broken. By the end of one side their mind wonders somewhere else. They are thinking about dinner or something, lol.
  6. CondoCruiser
    19,726
    18,734
    Apr 18, 2010
    Tennessee
    The main thing they look for is that air pressure builds to at least 100 psi and cuts off by 125 psi.
    Next shut the truck off and turn key to ON position for the buzzer. Put your foot on the brake and make sure it doesn't drop 4 psi in one minute. Tell him what you are doing as you do it. He might say okay instead of waiting a minute.
    Next is taking your foot off the brake. It shouldn't drop more than 3 psi in one minute.
    Next fan (pump) the brakes. The buzzer/light should come on before 60 psi.
    Next, continue fanning the brakes. The buttons should pop out between 40 -20 psi.
    The only other thing I can thing of is air pressure build up rate. At idle it is suppose to raise from 85-100 psi with in 45 seconds. Tell him that when you first build pressure or rebuild pressure.
    Do that and you'll pass the in cab brake part. Don't forget the other in cab controls.
  7. Oregon Grown
    Oregon Grown Light Load Member
    220
    86
    May 7, 2012
    lapine or
    yes you tube, there is a bunch of pti videos, watch the stupid trucker ones too,lol, learn by someone elses mistakes
