N14 back to PT pump, no STC
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Oldschool3400, Apr 11, 2023.
  1. Oldschool3400
    Oldschool3400 Bobtail Member
    13
    7
    Apr 11, 2023
    Want to build an N14 using N14 lower end, less cam and a BC 3 or 4 fuel system.
    Am I nuts?
    Were there any N14 mechanicals without STC?
  3. IH9300SBA
    IH9300SBA Road Train Member
    2,432
    24,001
    Feb 26, 2021
    Not that I remember for on-highway. There may be some industrial engine applications that didn't have it.
  4. W923
    W923 Road Train Member
    1,424
    4,411
    Feb 28, 2022
    I don’t believe any of the industrial ones I have seen were straight pt system…all stc. However the l10 and m11 were fairly common to be pt in the lower power and stc for higher ratings so possibly the n14 was also.
    Stc system was cummins way of getting better timing control. If you go 3406 cat they have a good timing system although it does need rebuilt more frequently than I would like.
    I am not so sure that regular pt injectors won’t fit in a stc n14 but you will need to disable the oil system and the fuel pump won’t care which injectors it’s running( a celect fuel pump will not work)
  5. wore out
    wore out Numbered Classic
    17,396
    216,174
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    What you’re gonna run into is the piston crown of the N-14 pistons won’t match any big cam injectors. They can be made to start and run but not right. I have known several people try…. All abandoned the idea pretty quick
  6. Oldschool3400
    13
    7
    Apr 11, 2023
    That brings this question, if memory serves I think I know.
    BC3-4 rods are not the same on the small end but would the BC rods and appropriate piston run on N14 Crank?
  7. Oldschool3400
    13
    7
    Apr 11, 2023
    Just finished overhaul of 2000 vintage N14 industrial it is STC.
    After studying the operation of STC I am of the opinion that the entire system could be done away with.
  8. wore out
    17,396
    216,174
    Jun 5, 2013
    No
    BoxCarKidd and Oldschool3400 Thank this.
  9. Oldschool3400
    13
    7
    Apr 11, 2023
    Your right.
    BC crank would run in N14 block but it all falls apart at the rod journals.
    Suppose could go that route and use BC rods, pistons right on up.
    But the N14 is way tougher.
    Thinking keeping it N14 STC just not using the STC valve and plumbing.
    It only runs advanced at idle and low load conditions.
    Use parts match per STC CPL.
    Still in the planning mode for now but have a running N14 and a 400Hp BC at my disposal.
    The N14 I have is celect.
  10. wore out
    17,396
    216,174
    Jun 5, 2013
    You’re begging for heart break but go ahead. Be sure to give us a 100k update
    BoxCarKidd, Oxbow and Siinman Thank this.
  11. Oldschool3400
    13
    7
    Apr 11, 2023
    You a driver?
