N14 celect plus opinion
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by boselog, Jan 8, 2021.
  1. boselog
    boselog Bobtail Member
    Hey guys
    In process of buying 1999 volvo vnl with cummins n14 celect plus. 13 speed and 3.73 rears. What's you'll opinion of this setup. Power, mpg...etc
  3. bad-luck
    bad-luck Road Train Member
    3,440
    6,337
    Nov 16, 2013
    Baltimore, Maryland
    N14 is an excellent motor. Used to own one, only thing I ever had to do to it was replace injectors and a cam sensor. Thinking you mpg will be around 6
  4. jamespmack
    216,637
    Great combo. But a 1999 volvo. Check floor boards, its a steel cab and they rust. Check frame for rust or repairs. They are known to rust.
    Crude Truckin' and pushbroom Thank this.
  5. olddog_newtricks
    olddog_newtricks Medium Load Member
    639
    2,164
    Jun 3, 2018
    Good engine , transmission and axle ratio . If it were in anything other than a Volvo. But that's just me.
    Rubber duck kw Thanks this.
  6. DUNE-T
    DUNE-T Road Train Member
    7,056
    17,193
    May 10, 2015
    Detroit, MI
    If it has 435hp or more, you can turn it all the way to 525hp.
    Mpg will be 6-7. Really make sure that there is not much rust on the frame. That is the death of these trucks, otherwise they run for a very long time
    DieselDisciple and Crude Truckin' Thank this.
  7. Iroc86
    Iroc86 Bobtail Member
    4
    I just bought a 96 FLD with N14 and 10spd trans. Its running good and strong. Lady I got it from had it leased to a company that required it be turned down to 65mph... I'm definitely turning back up. Any suggestions I should do to it before I stick her back over the road. Already did blow by and it was good.
  8. DUNE-T
    7,056
    17,193
    May 10, 2015
    Detroit, MI
    Just put an injector inside the truck as a spare, sometimes n14's have problems with them.
    Take the truck to a good mechanic to check everything out and get to work
  9. jamespmack
    216,637
    Do not do extended oil drains on a N14, Do not lug the motor. I like all the pre 2003 motors. I think the N14 doesn't get the credit it deserves. They will go 1.5 million miles. I always used cummins recon injectors. To many issues with aftermarket. Biggest thing I can think of is keeping a eye on accessory drive bushings.
