N14 Cummins low pressure (solved)
Discussion in 'Trucks [ Eighteen Wheelers ]' started by blanco, Apr 18, 2013.
  1. blanco
    blanco Road Train Member
    1,221
    296
    Nov 20, 2009
    Gwinnett County, GA
    Truck came in with low oil pressure. Battery of test indicated internal failure, but where?
    Dropped the pan and lo behold, what is this?
    Piston cooler nozzle broke off. We went ahead and replaced all 6. Cheap insurance. 916k miles . year 2000
    Heavyd Thanks this.
  3. Acm
    Acm Bobtail Member
    20
    5
    Feb 28, 2013
    I've seen that on a few n 14 engines.the older STC engines woulud smoke real bad when started when they break off too.
    blanco Thanks this.
  4. Smellfunny
    Smellfunny Road Train Member
    1,446
    967
    Jan 28, 2012
    South Carolina
    Did you drop a main bearing cap while you had the pan off?
  5. Heavyd
    Heavyd Road Train Member
    7,829
    6,279
    Feb 4, 2009
    Thanks for posting, it is nice to hear about problems being solved. Good call on replacing all 6.
  6. Littleitchy
    Littleitchy Bobtail Member
    15
    Apr 16, 2013
    Pine City MN
    Whats considered low oil pressure? I have 40-43 hot going down the rd and 20 or so at a hot idel.
  7. cetanediesel
    cetanediesel Medium Load Member
    470
    186
    Mar 26, 2013
    Albany, NY
    Thats good pressure. Cummins has a low pressure high volume system.
    Littleitchy Thanks this.
  8. 24valve puller
    24valve puller Medium Load Member
    399
    89
    Sep 8, 2007
    N.E. Oh
    only min. # for a n-14 is 10 psi at hot idle
