N14 Cummins runs & dies
Discussion in 'Freightliner Forum' started by dumbdish, Jun 16, 2011.
  1. dumbdish
    dumbdish Bobtail Member
    Wichita Falls, Texas
    N14 Cummins in a farm tractor. Mechanical governor. Factory rebuilt about 2 years ago. Unit starts, runs for about 5 seconds and smothers out as if it runs out of fuel. Starts right back up with same problem. Gravity feed fuel system. Tried two new fuel filters. Puled injection pump and sent in for repair. Still has same problem. Suggestions? Thanks
  3. bullhaulerswife
    bullhaulerswife Forum Leader/Admin Staff Member Administrator
    28,628
    46,039
    Jul 23, 2007
    Midwest
    Have you looked at the oil pressure sensor? Hubby had his go out and it would do exactly what you are describing. It will shut your engine down if it doesn't read enough oil pressure. Hubby says the sensor is on the bottom left side of the motor, just above the oil pan.
  4. dumbdish
    Manual engine, no electronics. Oil pressure comes up when running.
  5. poppy
    poppy "I Love that Cushaw Pie"
    263
    114
    Jul 31, 2007
    ky
    same problem once, took fuel lines off and blew a small gravel out of line from the tank.
  6. FYDA FREIGHTLINER CINCY
    FYDA FREIGHTLINER CINCY Light Load Member
    270
    131
    Apr 28, 2009
    Cincinnati, ohio
    make sure you don't have a rag or something like that in fuel tank blocking the pickup.
