N14 front main still leaks after replacement
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Cory wood, Aug 19, 2016.
  1. Cory wood
    Cory wood Medium Load Member
    335
    162
    Nov 7, 2015
    I have two trucks I have replaced front main seals on with n14 and the very next day they leak again. We have done both trucks three times with the correct cummins install tool and can't find any cracks or anything in the housing and still leaking. What am I missing here?
  3. 062
    062 Road Train Member
    6,349
    34,014
    Oct 20, 2013
    Have you checked for end play on the crank?
  4. Cory wood
    335
    162
    Nov 7, 2015
    Yes and both are good, one engine has 20k miles on a new out of frame.
  5. BigPerm
    BigPerm Medium Load Member
    Correct dipstick?
  6. Cory wood
    335
    162
    Nov 7, 2015
  7. TheDude1969
    TheDude1969 Heavy Load Member
    807
    823
    Jun 10, 2013
    Joliet, Il
    Sorry I can't help w/ N14 specifically... but you say everything else is good.
    If so, a new harmonic balancer
    A sleeve if one exists for the balancer?
    Your Main bearings are too sloopy.
  8. Cory wood
    335
    162
    Nov 7, 2015
    Main bearings are new in both trucks. One has a new balancer and one does not so will try the new balancer. Have tried with speedy sleeve and without
    TheDude1969 Thanks this.
  9. Ozdriver
    Ozdriver Heavy Load Member
    770
    1,394
    Oct 16, 2015
    Australia
    Does it leak from where it contacts the crank or around the circumference of the seal? All I can suggest is measure the run-out of the crank with a dial gauge. Usually leaking seals means incorrect installation, but I guess you must be doing all that OK. Pre-lubing the seal etc.
    What do Cummins and the seal manufacturer say?
  10. Cory wood
    335
    162
    Nov 7, 2015
    Run out is good and it's from the seal where it contacts the crank. Gonna really have to dissasemble one and see what's up
  11. BoxCarKidd
    BoxCarKidd Road Train Member
    4,558
    6,645
    Aug 26, 2014
    I do not know what you are missing and will answer this question as crankshaft seals in general. Some of these I am sure don't fit but I will just through everything I can thank of in the basket and hope pick out one the helps you.
    N14 cannot leak oil past the bolt threads because there is no sealant on them?
    Leaks oil between the balancer hub and crankshaft.
    Cummings seals are to be installed dry.
    Had a problem with an after market seal. Thought it looked funny anyway but installed it. Installed factory seal from Cat, it was a Cat, no problem.
    Crack in the balancer at the key way. They can be really hard to see.
    Have seen problems with seals ####ing at the beginning even with the proper tools. Watch for that and hand tools only.
    On sleeves and seals like that I have been using anerobic sealer for years. That red stuff they glue Detroits together with. Dries only in the absents of air. I feel it lubricates the seals and sleeves for easier installation. Seals any imperfections such as lines in housings from improper seal removal or spaces under wear rings.
    Does it not actually run on the crank nothing to do with the balancer? Install the seal 3/16 of an inch farther so it is on some new meat.
    Heavyd Thanks this.
