N14 injector swap...
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Gambi80, Aug 15, 2011.
  1. Gambi80
    Gambi80 Medium Load Member
    I've got an N14 with a 2592 CPL currently set at 525hp (turned up from 460) and was wondering if it would be advantageous to replace the current injectors (a couple are getting weak) with some from a 2659 CPL...525 from factory. According to some papers I found, the 2659 injectors have a 1/1000th's bigger nozzle vs. what I've got now. Good, bad, indifferent? Or will it just blow more smoke?
  3. STisma
    STisma Bobtail Member
    13
    Aug 17, 2011
    Midwest
    Negative on the above. Same injectors. Even if one had "bigger hole" still the same amount of fuel.
    BTW...how are the injectors getting weak?
  4. lovesthedrive
    lovesthedrive R.I.P.
    15,953
    54,484
    Nov 11, 2008
    Sorrento Maine
    Bigger hole only works better if your trucks mass air flow really thought you needed more fuel, otherwise you would be just spending dollars on a dream.
    If it is getting sluggish and engine runs fine I would look elsewhere, ie turbo.
  5. Gambi80
    It idles rough and smokes at idle as well...
    Anyway, I had a different issue with it recently and had to have the computer hooked to it, so I asked the guy to go through the cut-out and cylinder balance tests and came up with #2 and 3 being 'weaker'...guy said "they're not hittin as hard". I am by no means a good diagnostic mechanic, so I'll take his word for it.
    Sooo...Cummins has a buy 5 get a 6th free, so I might go that route. Do one or two, might as well do them all, the motor is going on 11 years old now.
  6. power freak
    power freak Light Load Member
    220
    60
    Apr 23, 2009
    I am no cummins expert but I imagine that every thing else being the same if u go with larger injectors you would gain power. I know on a cat the only difference between different flowing injectors is the tip so I can't imagine cummins being much different.
  7. lovesthedrive
    15,953
    54,484
    Nov 11, 2008
    Sorrento Maine
    The injectors are controlled by the mass air flow sensor. Having the potential of more volume does not mean you will get more volume. The mass air sensor needs more air to dump more fuel unless you bypass it.
  8. power freak
    220
    60
    Apr 23, 2009
    There is no mass air flow sensor on a n14 the fueling is controlled by the
    Boost pressure sensor input and throttle input plus various other inputs.
  9. STisma
    13
    Aug 17, 2011
    Midwest
    ECM and camshaft determine and trigger fuel amount and timing of injection via different sensors (crankshaft position, engine temp, outside temp, air-flow, engine RPM, TPS (throtle Position Sensor), transmission, MAP sensor (turbo sensor), etc.
    The function of the injector, ANY injector, is to receive, store, automize and spray the fuel. Injectors DO NOT determine when and how much of fuel is need.
    THUS, using "larger" can only create problems.
    The best and strongest fuel injector is one that is clean and adjusted.
    PS. CAT, VOlvo,...... do have options of getting "bigger" injectors, but that ALSO calls for other modifications. Not worth it for over-the-road and off-road use. Yes for competition.
  10. power freak
    220
    60
    Apr 23, 2009
    Yes I agree that the injector does not contol the timing or duration of the injection event it is a slave to the ECM. Although a injector with a bigger tip will inject more fuel than the smaller one and making more power so long as sufficient air is available to burn it. Exactly how much bigger the injectors are will determine if they are feasable for his application. If they came standard in the 525 Hp models than I do not think that they would Hurt the engine. Yes any time you add more power to a engine you are shortening the lifespan of the engine..... How much depends on the load factor and the driver.
  11. 112racing
    112racing Road Train Member
    1,384
    20,548
    Nov 30, 2008
    pocono's, pa
    at 5-600 each + install id just replace the bad ones and call it a day
