N14 Injectors Leaking Down?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by NebraskaGMC, Nov 18, 2024.
  1. NebraskaGMC
    NebraskaGMC Bobtail Member
    37
    13
    Jun 9, 2019
    Had a misfire in my Celect Plus so I put all 6 new injectors in. Before this I also had an issue where if the truck would sit for more than 3 days or so, it would crank unevenly and when it would start it would dump a ton of black/gray smoke out the pipes. After the new injectors it runs perfectly smooth again, but it started doing the uneven crank and dumping smoke on startup after it sits for a few days again. Did I just luck out and get another leaking injector out of the box or is there something else that can cause this? It's definitely raw diesel smoke not antifreeze as well. Never did check which cylinder was doing it before the 6 pack, so I won't know whether it's the same one or not.
  3. J.R.
    J.R. Light Load Member
    65
    184
    May 17, 2012
    WI
    I was told after I did a six pack, just replace the problem injector due to the poor quality of most Cummins reman parts.
    They say clean your ground's, while you will find some corrsion somewhere, I think unhooking battery's and doing a ECM reboot is often what helps?
    I've had the out of the blue popping chugging, smoking thing also??
    Next time starts normal.
    One thing that seems to proceed wierd starts is rushing a start, I count 15 seconds to allow ecm click thru and it seems to help.
    They are frustrating little red head girls:)
  4. NebraskaGMC
    37
    13
    Jun 9, 2019
    It's not really out of the blue, once it's running it runs flawlessly. It's just on startup sometimes after it sits a while
  5. DUNE-T
    DUNE-T Road Train Member
    7,046
    17,160
    May 10, 2015
    Detroit, MI
    I had the same thing. It started after I ran 600 miles with a bad injector. Apparently it washed out a cylinder I was told. After changing injectors, ecm, harness, fuel pump and whatever else, I ended up with a hole in the block .
    Big Road Skateboard Thanks this.
  6. NebraskaGMC
    37
    13
    Jun 9, 2019
    Well that sucks. I sure hope it's not that because this has 100k on an out of frame
  7. DUNE-T
    7,046
    17,160
    May 10, 2015
    Detroit, MI
    Lol mine had 200k on new engine. That really hurt
  8. NebraskaGMC
    37
    13
    Jun 9, 2019
    Did it stick an injector and kick a pushrod?
  9. DUNE-T
    7,046
    17,160
    May 10, 2015
    Detroit, MI
    I never found out what happened, did not want to pay for the labor to investigate
  10. Big Road Skateboard
    7,096
    40,270
    May 2, 2021
    You may have a compression issue, and not a fuel issue.
    You're gonna have to isolate the hole first, then diagnose from there.
  11. NebraskaGMC
    37
    13
    Jun 9, 2019
    I don't think it's a compression issue, for a few reasons. Reason 1 is that it never does it if it only sits overnight. Reason 2 is that the cylinder that sounds "off" when cranking sounds like it slows the engine down rather than a skip. Reason 3 is that when it starts to fire while the issue is present, one cylinder starts hitting before the rest. When I get time I'm going to pull the exhaust manifold and see which one is doing it
