N14 Jake brake issue
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by killalol, Jul 8, 2022.
  1. killalol
    killalol Bobtail Member
    15
    4
    Apr 15, 2022
    Hello!
    Yesterday , after turning off my engine brake I would accelerate and it would sound like the engine is knocking . Like the engine brake is engaging .
    I was wondering if it’s safe anyways or should I just avoid the engine brake ?
    I saw that it could be the solenoid , what else can it be?
    thank you!
  3. killalol
    15
    4
    Apr 15, 2022
    Forgot to mention it’s peterbilt 377 with a Cummins n14 celect plus
  4. Inderjit
    Inderjit Heavy Load Member
    768
    735
    Sep 17, 2017
    I suspect you have a broken inner spool valve spring. This is a common problem and I would advise not to use the engine brake until it is repaired. While you are in there replace all six of them.
    killalol, spsauerland and pup Thank this.
