N14 missing around 1500-1600 rpm
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Mad dog logistics llc, Jun 6, 2023.
  1. Mad dog logistics llc
    Mad dog logistics llc Light Load Member
    152
    37
    Jan 13, 2014
    Truck misses around 1500-1600 rpm on the high side when heavy. Once you pass 1600 goes back to normal and can drive at 1600 rpm no problem just gives you trouble when trying to get up to speed.
    No check engine lights or faults. ( have a Motive device which will tell me if theres a fault )
  3. DUNE-T
    DUNE-T Road Train Member
    7,085
    17,266
    May 10, 2015
    Detroit, MI
    Most likely injector
    Big Road Skateboard Thanks this.
  4. Big Road Skateboard
    7,542
    43,253
    May 2, 2021
    I would agree it's likely an injector. I like to run return fuel into a clean 5 gal bucket and look for aeration. I've seen loose injectors cause similiar symptoms.
    Will it miss if you just throttle up under no load?
  5. Mad dog logistics llc
    152
    37
    Jan 13, 2014
    Only misses when loaded and its worse when heavy if you bobtail its fine. Only between 1500-1600 then goes away.
  6. Heavyd
    Heavyd Road Train Member
    7,838
    6,293
    Feb 4, 2009
    Unplug your injector connectors one by one until the miss doesn't change, then you have found your faulty injector.
  7. S.truck
    S.truck Bobtail Member
    i have a truck doing the same thing, you ever solve your issue?
  8. Transportauto
    Transportauto Light Load Member
    100
    34
    Apr 10, 2022
    Only between 1500-1600 if you have a spare ecm to try. Injector maybe but only for 100 rpm span then goes away? Only on high side? Goes away after?. I'd venture out to say it is a bad injector or harness that is missing or weak all the time your just missing it because the engine isn't fully loaded on the low end or your a high shifter. I'd run her down to 800 rpm in highest gear and hammer it, you might feel it the whole time just more pronounced around 1500.
    Shot the exhaust after a run look for heat difference between cylinders.
  9. Mad dog logistics llc
    152
    37
    Jan 13, 2014
    battey cable was shorting out. I use the cable that connects all the batteries and there was a break which wasnt supplying the ecm with the correct volts under a load
  10. S.truck
    I found my issue, it was the #3 injector harness/pass thru. Manual says resistance range is .5-1.5 ohms for injector threaded contacts, injector internal harness, and injector pass thru connector, I checked out all 6 injectors, their jumper harness's and the pass thru's and stayed around 0.6-0.8 0hms, #3 was at 17k ohms, but only when the internal jumper harness was connected to the pass thru, the rest of the time it had readings like the others. telling me the pins were spread on the deuch connector causing high resistance. hopefully I've explained that good enough.
