N14 Red Top Jake Question
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Auctioneerhere, Dec 30, 2011.
  1. Auctioneerhere
    Auctioneerhere Bobtail Member
    32
    11
    Dec 23, 2010
    MT
    How can I tell if this engine has a jake on it?
    Is there something to look for on the red top cover?
    I see no Jake switch in the cab, but at the same time I see the wiring on the clutch.
    Thanks
  3. Heavyd
    Heavyd Road Train Member
    7,830
    6,282
    Feb 4, 2009
    The next layer under the rocker cover is the Jake section. It is about 2" thick, then the rocker box which is about 5" thick. If all you have under the rocker cover is the 5" section, then the head, it doesn't have Jakes. Also, on the right side of the engine the Jake housings have a single wire connected to each section, (housing). There will also be a Jake Brake id tag on the right side of the each housing too.
    Auctioneerhere Thanks this.
