N14 scored cylinder
Discussion in 'Trucks [ Eighteen Wheelers ]' started by rollinsmoke10, Oct 26, 2016.
  1. rollinsmoke10
    rollinsmoke10 Bobtail Member
    26
    Oct 11, 2009
    I have a 93 pete with a N14 mechical engine that I just rebuilt 10k ago and it scored #6 cylinder agian. I bought the truck with the same issue (#6 scored cylinder). Water pump was replaced, piston jets replaced, oil pump replaced, injectors were rebuilt by a good diesel shop, plus the normal overhaul parts. I'm not the one always driving the truck so I cant tell you for sure if it ever overheated. Any suggestions on what to look for?
  3. Heavyd
    Heavyd Road Train Member
    7,826
    6,276
    Feb 4, 2009
    Oil passage blocked for the oil cooling jet.
  4. rollinsmoke10
    26
    Oct 11, 2009
    I pulled the piston cooling nozzle and checked for blockage but it was OK
  5. BoxCarKidd
    BoxCarKidd Road Train Member
    4,549
    6,641
    Aug 26, 2014
    I heard of an ECM causing a problem like that. Saw a Massey Ferguson repeat that problem, bent rod, but your kit probably included rods. Was the new liner ID checked with a dial bore gauge?
  6. Heavyd
    7,826
    6,276
    Feb 4, 2009
    No, I mean the actual passage in the block, make sure it is clear.
    BoxCarKidd Thanks this.
  7. cumminskid123
    cumminskid123 Light Load Member
    107
    59
    Jun 21, 2016
    Manitoba, Canada
    Maybe a bad connecting rod? Unless they're all new
  8. AModelCat
    164,801
    Never touched an N14 but what about poor coolant flow at the back of the block?
  9. wrenchman
    wrenchman Bobtail Member
    16
    7
    Nov 4, 2016
    Hey Rollin, if you have made certain the piston cooling nozzle and passage is flowing oil, and the cooling system is open and flowing correctly in the block and head, perhaps did a liner o-ring get rolled, been there done that. You stated it is a mechanical N14, That means it is a STC engine, that being stated, it could be an issue with the STC/HVT system. I have found shop rags, paper towel and so forth blocking cooling and oil passages. Perhaps, though, it is only #6, not #5 also, anyone check the cam follower timing? Just thinking out loud. Take care, good luck.
