N14 select plus skip,smoke,rough idle
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Rc1234, Sep 28, 2019.
  1. Rc1234
    Rc1234 Bobtail Member
    18
    4
    May 31, 2018
    started suddenly after hitting rough road..#3 injector failed cutout test,dealer replaced..no change..still rough shake at idle,lots of black smoke under load,strong fuel smell,ticking noise...
  3. Bakerman
    Bakerman Road Train Member
    4,663
    8,812
    Jan 27, 2013
    Phoenix, AZ
    Return fuel line blocked?
  4. Heavyd
    Heavyd Road Train Member
    7,798
    6,239
    Feb 4, 2009
    Check basics, check your electrical connections, but it also sounds like the fuel is aerated. Fuel line on the suction side might have cracked enough during the bouncing to allow it to be sucking air now.
    Bakerman Thanks this.
  5. mrbamcclain
    mrbamcclain Light Load Member
    258
    116
    May 25, 2011
    Hammond, La
    Swap #4 to #3 see if the problem remains. Replace the pass thru connector.
    Last time overhead was run?
  6. Rc1234
    18
    4
    May 31, 2018
    All the above ok...suspect broken valve....
  7. Rc1234
    18
    4
    May 31, 2018
    Found broken exhaust valve...hope piston is ok...the dealer I am stuck at is unbelievably slow...more later...
