N14 turbo replacement
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by mile marker 27, Jan 13, 2025.
  1. mile marker 27
    mile marker 27 Road Train Member
    1,427
    1,741
    Dec 4, 2019
    This is a 460hp, 1580 CPL. Whose ya’lls choices for buying a replacement turbo from? Heavy & Highway has them from Interstate McBee. FleetPride has Borg Warner and Holset. Prices from these three, range from $1050- $1600. Any other recommendations, aside from CumminGs?
  3. SmallPackage
    5,985
    19,368
    Dec 20, 2019
    Marion Texas
    I’m old school I still call the Borg Warners, Schwitzers. Those were the original turbos used by Cummins long before they bought Holset. Great sound. Tried and true and many went millions of miles. Legend has it, If you had a pump set just right you could make a schwitzer whistle at idle on the peddle with your toe as a woman walked by a row of parked trucks. Lol.
  4. DUNE-T
    DUNE-T Road Train Member
    7,107
    17,345
    May 10, 2015
    Detroit, MI
    Only original Cummins reman
    Heavyd Thanks this.
  5. Heavyd
    Heavyd Road Train Member
    7,843
    6,298
    Feb 4, 2009
    For parts like this, check into the progressive damage warranty coverage. This means, if an aftermarket turbo fails and ruins your engine, does the aftermarket company cover the progressive damage to the rest of your engine their failed part caused? Many of them do not.
    BoxCarKidd Thanks this.
  6. JAKsDiesel
    JAKsDiesel Bobtail Member
    Unheard of on turbos and not likely that will happen. Too many people attempt a turbo and diagnose the issue wrong. I have yet to see a turbo ruin an engine.
  7. JAKsDiesel
    Better off buying a Holset new or Reman if your set on OEM. You also won't get stuck having to to take it in to a certified Cummins shop if it fails. Pretty simple turbos not likely.
  8. mile marker 27
    1,427
    1,741
    Dec 4, 2019
    Bought a new Holset, from Interstate McBee.
  9. DUNE-T
    7,107
    17,345
    May 10, 2015
    Detroit, MI
    How much was it?
  10. mile marker 27
    1,427
    1,741
    Dec 4, 2019
    Too much,……….. $1338.
    DUNE-T Thanks this.
