NavistarServiceInfo.com Subscription Question
Discussion in 'International Forum' started by EzGoingKev, Jan 8, 2015.
  1. EzGoingKev
    EzGoingKev Bobtail Member
    11
    Dec 18, 2014
    Does anyone here have this? If so does it let you view the OE parts diagrams along with the OE part numbers?
  3. EzGoingKev
    11
    Dec 18, 2014
    Nothing? No one subscribes to this?
  4. Heavyd
    Heavyd Road Train Member
    7,826
    6,276
    Feb 4, 2009
    I am a dealer technician. What we use is totally different. I did check out the site. From what I read it is service only, no parts.
  5. EzGoingKev
    11
    Dec 18, 2014
    OK thanks.
    We are looking into getting OnCommand which I believe has everything.
  6. localyokal
    localyokal Light Load Member
    140
    64
    Nov 2, 2013
    does this navistar service info give complete service history on motors?
  7. Heavyd
    7,826
    6,276
    Feb 4, 2009
    No, just repair information.
  8. localyokal
    140
    64
    Nov 2, 2013
    is there a such service where i can get a complete history on the maintenance? I got 1 year worth of history records from the previous owner and I did a rigdig but thats about it.
  9. Heavyd
    7,826
    6,276
    Feb 4, 2009
    Depends. Any International dealer will be able to access all warranty repairs performed on any International truck. All they need is the last 8 of the VIN. As far as complete service and repair history, this is impossible unless you know exactly where the truck went for service and then ask those specific shops for their records on at particular unit. Dealers are not linked together. If a truck had an oil change at dealer in Florida, then another oil change in Calgary those dealers are not linked together and neither is the service history. If an International truck is repaired or serviced at a Pete dealer, same thing, not linked. Again if the truck is serviced at Bob's Garage only that garage will have repair records for they specifically did. You would have to track down exactly all the shops that particular truck went to in order to get complete history.
  10. localyokal
    140
    64
    Nov 2, 2013
    thanks for the comeback heavyd. I would contact the original owner but they are no longer around (USF GLEN MOORE) im a little curious because at 1.1 mil on the motor it still has great oil pressure and clean oil samples.
