nee alignment shop in chicago
Discussion in 'Trucks [ Eighteen Wheelers ]' started by hoofhappy, Jul 11, 2011.
  1. hoofhappy
    hoofhappy Bobtail Member
    texarkana, ar
    anyone know a good alignment shop in the chicago area? I have been to 3 shops and had 3 different answers...bad shock, needs alignment, bad king pins and need the axle replaced. I see nothing wrong with the shock so I do believe it's the kingpins.
    any input would be appreciated. thank you.
  3. Heavyd
    Heavyd Road Train Member
    7,826
    6,276
    Feb 4, 2009
    What is the problem?
  4. Superhauler
    Superhauler TEACHER OF MEN
    12,209
    100,735
    Jan 30, 2010
    keep stroking.
    easy to check shocks after running down the road for a good part of day touch the shocks, if warm they are still working, if cold replace them. king pins jack up the axle an try to move the tire in and out any movement kingpins are worn or loose bearings.
  5. gregor
    gregor Light Load Member
    90
    19
    May 13, 2011
    chicago,il
    just don't go to EIMA aligment shop!!!!! they do what you want but not correct and when you get back to them they refuse to make it again ,they find 100 reasons to not make it right again example bad tires, shocks, bad tire preassure and so on......
  6. Heavyd
    7,826
    6,276
    Feb 4, 2009
    If you have a shimmy or shake, or vibration an alignment will not fix it. Something is broke or worn.
  7. trucker2009
    trucker2009 Bobtail Member
    10
    Sep 18, 2009
    Don`t go there for sure i lost 3 set of steer tires by wrong aliment.
    good place where i go is
    Wingfoot Commercial Tire Systems
    www.wingfootct.com -
    16701 Van Dam Road, South Holland -
    (708) 331-3700
  8. jesterx
    jesterx Bobtail Member
    7
    Wisconsin
    I cant recommend anything in Chicago but in the Milwaukee area I know of 2 good shops.
