Need a radio suggestion (First "big" radio purchase)
Discussion in 'CB Radio Forum' started by Zephex, Oct 21, 2015.
  1. Zephex
    Zephex Light Load Member
    161
    112
    Jul 8, 2013
    Blue Ridge GA
    Hey everyone.
    Been driving for 3 years now and I have had 2 radio's in my history. An old cobra 29, until it went south....dont know what happened to it really. I then bought a Uniden Bearcat 980. Dont use SSB but it was on sale and only like 20 bucks more so I grabbed it.
    Im about sick of the Uniden. Its pretty, but I dont like the way it receives. It seems to play a lot of noise. When I turn the squelch up or the RF Gain down, voices are clearer but it really drops the range. Other times I get conversations that cut in and out just being on the edge of the squelch control. So I get things tha sound li this quite oft n and it reall gets n my nerv es.
    I would like suggestions on a radio that has better reception or rather a radio that is better at distinguishing voice from noise. Maybe a bit more wattage output? I rarely talk on the CB but I do warn other drivers about police and road hazards so if Im getting a new radio, why not. Only catch to that is that since it is a company truck, I need to be able to use existing power wires. Keep that in mind.
    Echo, Roger Beep, and all that stuff are just extras. I dont need them, probably wouldn't use it anyway but if it comes with the radio thats fine but certainly not a requirement.
    I do have a HAM license (KI4SXY). I am in a cascadia running a top loaded 4ft firestick II on the stock cascadia mount. I know the coax is not optimal but I have tried using the mirror mount and it just doesn't seem to work as well. My SWR is 1 using the Firestick where it is now.
    I just do not have any experience at all with all the brands out there. Galaxy, Stryker, General, Connex, Magnum, etc etc etc.
    Thanks in advance for your help and suggestions. I look forward to reading your replies.
  3. kelgar50
    kelgar50 Medium Load Member
    334
    218
    Feb 1, 2007
    Bakersfield,CA
    I love my Stryker 955 but if you do not want ssb you could go with the Stryker 655. It is the same radio without side band. The receive is the best out of the radios I have had in the past and they are very clear and have quite a few features. Power output is good I'm in a company truck also and run the power cord that came with the radio into the connection for the cb hook up with a 15a fuse. For an antenna I use a Predator 10K Bad to The Bone. IMAG0330.jpg
  4. Neverready
    Neverready Medium Load Member
    406
    330
    Jul 24, 2014
    Pocomoke City, Md.
    The Galaxy 959B comes from the factory with the receive upgrade many cb shops sell Schottsky? a little higher price than the original 959. The 959 also has SSB which you said doesn't interest you so you would have to decide whether it is worth while. The 959 likely wouldn't do any more than 6 to 8 watts am with a tune just tweaking factory components. I have not used a 959B just considering my trading my 959 for the newer model.
  5. poppapump1332
    poppapump1332 Road Train Member
    2,986
    2,464
    Jan 2, 2010
    birdsboro,pa
    Styker has great receive.
  6. Ougigoug
    Ougigoug Heavy Load Member
    971
    824
    Dec 4, 2012
    Planet earth
    Maybe you should look at the general lee or connex 3300HP these 2 radios look plain just like cobra 29, i mean they aren't too flashy a doesn't attract attention.
    Both radio are proven technologies, both are around for long time and they both yield some power just enough for you to run them with regular power cord you only might have to use a bigger fuse.
    As for TX/RX it all depend on who are you going to use as CB SHOP my first choice would be DTB in Carlisle but this is personal taste.
    One last thing make sure SWR is right and you will enjoy your radio.
    Good luck
  7. delta5
    delta5 Road Train Member
    1,193
    7,404
    Sep 9, 2010
    RCI Ranger 2970N2. It has a real VFO and works great on 10m and 12m bands. Just don't let anyone do a bs peak n tune or any "super-mod" crap.
  8. volvo244t
    volvo244t Road Train Member
    1,775
    1,779
    Jun 24, 2010
    Bettendorf, IA
    Stryker 955. The 655's receiver isn't quite as good, and it's not as good at adjacent channel rejection either.
    And get a 7' Firestik for the mirror arm. Run it as a dipole. That's the setup I run, and I can do 20 miles easy, more in the flat lands. I talk skip all the time as well, including many rolling sideband contacts. SWR is 1.
    I see so many Cascadias running around with shorty antennas on the mirror arm. (Anything less than 5' is a "shorty" for the mirror arm.) Shake my head every time I see it.
  9. mike5511
    mike5511 Road Train Member
    3,162
    1,549
    May 15, 2011
    NW Arkansas
    In my experiments, the 5ft is just barely adequate. Anything less is totally inadequate! A dipole or are you using a counter-poise?
  10. Chris Yohn
    Chris Yohn Bobtail Member
    15
    8
    Jun 10, 2015
    Thanks for your suggestions. I can look into a longer firestik and mounting it on the mirror. Tried that with my 4' and it wasn't so good, bad swr. Probably just not tall enough. I'll look into the stryker radio then. I really appreciate the help.
    Oh. Is there any online shops that are trustworthy? One that I can buy the radio and have them peak and tune it before its shipped to me?
  11. volvo244t
    1,775
    1,779
    Jun 24, 2010
    Bettendorf, IA
    http://www.finetunecbshop.com
    Get in touch with Mark. He is on Facebook. The "Hardrive" link on that ^^ page will link you to his FB page. Have him peak and tune it and you won't get a better radio anywhere, from anyone. He's the only one I've seen that has the proper test equipment, knows how to use it, and uses it 100% correctly. His results speak for themselves (literally.)
    edit:// here is a recording of a guy who has a Hardrive-tuned radio:
    edit2:// you can get a 7' Firestik at Bob's CB Shop in PA, I-80 exit 70.
