Need advice on axle weights
Discussion in 'Experienced Truckers' Advice' started by Rockdoctor, Feb 15, 2019.
  1. Rockdoctor
    Rockdoctor Medium Load Member
    I'm trying to figure out if I need to slide my fifth wheel? I have a daycab and a crude oil trailer so I can't slide the trailer tandems. I just purchased the trailer and own the truck so once I get this set up I won't have to move anything around in the future.
  3. Diesel Dave
    9,718
    33,195
    Jan 20, 2010
    Hesperia, Ca.
    The scales are not gonna bother you for 100 lbs. I would roll.
  4. blessedman
    blessedman Light Load Member
    296
    230
    Feb 15, 2013
    Doniphan, Mo
    Slide your 5th wheel forward one notch. Hopefully you have a 13,000 pound front axle instead of a 12,000 pound.
    Since you can’t change the trailer axles sliding the 5th wheel or rearranging the load are your only options.
    As the other post says you probably won’t be bothered over 100 pounds, but you never know.
  5. Diesel Dave
    9,718
    33,195
    Jan 20, 2010
    Hesperia, Ca.
    For your piece of mind, you can slide a notch forward if you want. But if it was me.... I would roll with it.
    TripleSix, MACK E-6 and Grumppy Thank this.
  6. STexan
    STexan Road Train Member
    14,963
    29,160
    Oct 3, 2011
    Longview, TX
    If you’re full of fuel, yes, slide the 5th wheel forward 1 notch if it’s available then forget about it. I’m not worried about the 100 pounds per se. it’s just that you may as well optimize your setup 1 time and be done with it but do this when you’re full of fuel.
    Rockdoctor Thanks this.
  7. I glide 47
    I glide 47 Road Train Member
    1,426
    1,523
    Jun 3, 2017
    Slide your seat forward one notch and call Jenny Craig
  8. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,144
    Mar 5, 2016
    White County, Arkansas
    That 100 pound over, Im not worried about it. You can burn that off in fuel tanks when you drive forward far enough. It must still be winter, making fuel somewhat heavier in density still.
  9. Liquidforce
    Liquidforce Light Load Member
    273
    287
    Sep 27, 2016
    Savannah GA
    I’ve got a few 2012-on Volvo days cabs, and was playing round with the fifth wheel this week, bottom scale is all the way back, top one is two notches forward, which puts the center of the king pin just past the center line between the drives. Each notch is near enough 500lbs weight transferred in my setup.
  10. Bill51
    Bill51 Road Train Member
    1,185
    2,982
    Jul 27, 2015
    Rockdoctor,
    Is it a one compartment trailer?
    If two or more compartments, who loaded it?
  11. Rockdoctor
    It's a one compartment 200B tanker.
