Need Advice on Urgent situation, scheduling situation.
Discussion in 'Questions From New Drivers' started by RdRunnr, May 4, 2019.
  1. RdRunnr
    RdRunnr Bobtail Member
    Okay so diving right in I need some advice..
    So I drive for JB Hunt delivering Amazon freight.
    I drive at night usually 8pm but I have a 2 hour window (which is not accurate at all tbh but that's another thing entirely).
    My previous tour started at 5pm and ended 2am 2 days later.
    My next tour following a 10 hour break started at 9pm. 19 hours later and 9 after I finally fell asleep. I tried staying up later but fell asleep at around 4am. Woke up at 12pm. 9 hours until I start then have to work 14.
    Now I talked to 2 different dispatchers within my company who had 2 different responses on the situation. And I need clarification on if this is my mistake or a scheduling problem.
    I have worked shifts like this in the past and forced myself to be awake (safely I might add) but it is very challenging and exhausting.
    So I guess my question is, is a 20 hour gap between assignments on opposite schedules a problem for you drivers? Would you work that or is being up for almost 24 hours a big scheduling problem.
    Because I'm being made to feel it is 100% not a scheduling problem and I should have taken a nap for a couple hours and powered through. (Keep in mind I've done that in the past but it's not so easy for me to fall asleep when I'm wide awake).
    But like I said one dispatcher said it was a scheduling error and the other it's on me.
    If I'm doing something wrong please let me know. I'm trying to fix this but I am of the mindset that a 20+hour gap is too big to turn around.
  3. starmac
    starmac Road Train Member
    6,639
    12,528
    Apr 11, 2019
    Fairbanks Ak
    I guess I am not seeing the problem. If I understand it right, you got 8 hours sleep and you hav e9 hours to go before your shift starts. Just rest some during the 9, A lot of truckers schedule changes with the load of the day.
  4. Ridgeline
    22,742
    123,695
    This isn't a thing where you can just do what you want, customer's needs come first. Learn how to handle sleep schedule changes better, but if you can't look for a 9 to 5 type work where you are in bed the same time every night. I get some people can't handle this, it is impossible for them to adjust to the sleep schedule.
    Lumper Humper and Lepton1 Thank this.
  5. bryan21384
    bryan21384 Road Train Member
    15,761
    34,352
    Sep 18, 2009
    Memphis, TN
    Once you wake up, dont get out of bed. Or worst comes to worst, you could rub one out and go back to sleep
    Lumper Humper, TravR1 and exhausted379 Thank this.
  6. bryan21384
    15,761
    34,352
    Sep 18, 2009
    Memphis, TN
    Or hit the buffet and get really full, it's no getting up after a buffet or heavy meal
    D.Tibbitt and Lumper Humper Thank this.
  7. Wicked Wizard
    Wicked Wizard Heavy Load Member
    985
    857
    Jul 15, 2008
    Northeast PA
    If this is the nature of the account you are on and you cannot handle the different start times then switch to another account with the same starting time. Sleep patterns are different for everyone. The dispatcher could care less as long as you legally got your 10 hour break in.
    dunchues and speedyk Thank this.
  8. To keep in the trucking industry.
    You pretty much need to sleep on command. Your head hits pillow you should be asleep shortly.
    Avoid doing activities in your sleeper till you can control your sleep pattern.
    Examples ( don't watch TV or movies, play video games)
    My wife hates when I come to.bed. my head hits pillow and I'm asleep in moments. Really pisses her off when I am asleep.before she's done talking to me.
    It's a habit to train yourself, you never know when you will need to be tested before a load.
    Good luck
  9. Flat Earth Trucker
    4,321
    16,669
    Nov 19, 2018
    I don't know if that is challenging, safe, or exhausting. :confused:
  10. Humblepie
    Humblepie Pontificator
    5,077
    80,318
    Dec 25, 2018
    I say #### em! Find something that fits you.
  11. Brandt
    Brandt Road Train Member
    4,632
    6,368
    Sep 17, 2012
    People can't sleep on command unless they are tired. It's little trick people tell themselves and dispatcher. If You can sleep anytime your a good driver. I was told that. They like to say that so your always rested and ready to drive safely !
    You can't sleep unless your tired. So if someone can sleep anytime they lay down they probably are tired and don't even know it.
    Sound like your getting a bad deal. In my opinion. I drive basically the same hours every day. I start say 7 am then I can work till 9pm. Then take 10 hour off get back up at 7am. It sounds like you're being forced to take say 15 or 20 hours off then going back to work. Because of that much time off you get the weird rotating schedule. Then dispatch could care less and says thing like you can sleep 20 hour and get up and work 14 hours. All dispatch cares about if it legal and hides behind that. That's a bad deal in my opinion. Your not a robot.
    Remember the Walmart driver and Tracy Morgan accident ? The Walmart driver sleep like 10 hour at home. Then was up all day. Then got in his Walmart truck for his 14 work schedule. So he was awake for about 23 hours. Then had traffic accident and killed one person. Tracy Morgan is lucky to be alive today. His log book was legal. Except New Jersey got him on some law about being awake 23 hour and driving. Walmart paid big money for not caring about that before. Today Walmart won't let that happen again. You can't work for Walmart and live 500 miles away from the DC and drive to work anymore.
    I would look for a driving job were you work the same hours, like I do. I'm not sitting for 20 hours off just so dispatch can mess up my sleep schedule then tell me I'm supposed to work 14 hour. If I want to drive all night I would get job driving for FedEx or UPS.
    What people don't say about driving all night is when you go home, you basically have keep the same schedule. So you go home and everyone else is sleeping at night and you still up doing nothing all night at home. I did some dedicated all night runs in the past. When I went home after driving all night you want do thing at home. That messed up you sleep schedule because you up like 23 hours. Not worth it in my opinion today.
