Need advice
Discussion in 'Questions From New Drivers' started by Marktrav1, Feb 13, 2024.
  1. Marktrav1
    Marktrav1 Bobtail Member
    Feb 13, 2024
    Failed pre employment for CBD oil i completed sap but cant find anyone to give me my rtd testing
    bryan21384 Thanks this.
  3. tscottme
    tscottme Road Train Member
    2Tap Thanks this.
  4. Marktrav1
    Feb 13, 2024
    I know i learned that the hard way
    tscottme Thanks this.
  5. Concorde
    Concorde Road Train Member
    5,486
    19,496
    Jun 29, 2016
    West Melbourne Florida
    How much experience do you have?
  6. Marktrav1
    Feb 13, 2024
    None man that was my first job after i got my cdl
    Chinatown Thanks this.
  7. Chinatown
    Chinatown Road Train Member
    77,796
    184,745
    Aug 28, 2011
    Henderson, NV & Orient
    Home [cdlstep5.com]
    Wargames Thanks this.
  8. Blackjack55
    Blackjack55 Light Load Member
    103
    192
    Sep 24, 2018
    That is probably the end of your driving career,before it even started. I'm sorry for you and not judging you,but keep yourself better informed
    2Tap Thanks this.
  9. 201
    201 Road Train Member
    12,791
    26,323
    Apr 16, 2014
    high plains colorado
    I read, CBD will not show up on any drug test, and the only way it will, is if contaminated with THC from another source, aka, regular weed. Sorry, doesn't look good. There is poor control of what goes into CBD, and very well might have had THC. Today it's black and white, and CBD is kind of a gray area, but in itself will not cause a false positive.
    Will CBD Show Up on a Drug Test?
    2Tap Thanks this.
  10. Ex-Trucker Alex
    Ex-Trucker Alex Road Train Member
    1,549
    2,704
    Jan 7, 2023
    Giving you the benefit of the doubt that it really was CBD oil, in this business you must know that there are certain supplements and herbs which are insanely close genetically to prohibited substances, and which sometimes will give you a false report. There IS a mechanism to challenge the test, and these tests are NOT infallible. You should DEMAND a retest, possibly suggesting litigation if you are refused (or at the very least a call to your state employment department). And, by all means, STICK CLOSELY TO YOUR STORY; any good attorney will try to prove that you actually just smoked a doob and are using CBD oil as a false-front. Be VERY careful with this. Unfortunately, THC takes WEEKS to clear from your body, so you should go nowhere even near a CBD oil, or even a person smoking weed. If you are lucky and it's been a week or 2, what THC was in your system MAY be dissipated enough by now to give you a clean test. THC generally take 6 WEEKS to clear your body, and no amounts of 'gin and juice' is going to change that. So, if the reality might be that you 'gave up' pot a full month before, well, it was still in your system. DO NOT TELL ANYBODY THIS if it is closer to the reality here; you will only be shooting yourself in your foot by doing so.
    FWIW, you MUST avoid CBD oils (THC), and poppyseeds (Opiates). Prilocaine creams can also give false test positives for cocaine. There are other issues, but most are pretty rare.
    Wargames, bryan21384 and tscottme Thank this.
  11. tscottme
    Some of the makers of CBD are not strictly following procedures and contamination with small amounts of THC is not their problem.
    201 and 2Tap Thank this.
