Need Engine Advice
Discussion in 'Ask An Owner Operator' started by mikey747, Jun 10, 2020.
  1. Brettj3876
    Brettj3876 Road Train Member
    11,257
    54,060
    Nov 18, 2014
    Land of local
    I would give the X12 a hard look if staying below 80k. Top of the line isx 12 is 1750 for tq. We ran 2010-2013 425/1650 isx 12 in the oilfield and hardly had any emission related issues
    mikey747 Thanks this.
  3. AModelCat
    164,983
    The "bigger is better" train of thought is old school thinking now. As you know, diesels love to be worked. Better to run a 13L hard than to barely work a 15L.
    mikey747, PE_T, daf105paccar and 2 others Thank this.
  4. PE_T
    PE_T Road Train Member
    Freightliner is the highest seller of trucks. Their trucks almost always come with a Detroit engine like the DD15. Because they are so popular, you will find a lot of videos on YouTube showing you how to repair it yourself or even what the common problems are so you can keep an eye on the symptoms.
    Whatever decision you end up making, make sure you find the maintenance manual of your truck and also your engine and read it.
  5. Stringb8n
    Stringb8n Road Train Member
    1,705
    2,236
    Sep 27, 2015
    is royal purple good or just an overpriced color purple?
    One company I worked for back in 2015 when I was doing heavy haul had bought a KW T-800, with a Cummins in it. 2850 miles later it was at KW getting a crate motor put in it, also from Cummins. Far as i know personally that was the worst cummins experience I've ever heard of. It was all covered under warranty. Company I worked for took it personally against KW. They had nothing to do with cylinder liners failing in the engine, though.
    Paccar the daycab I drive where I work now has that. 2013, and I think its the mx-13, could be wrong. I'd rather drive a mack, with a pussycat on a stick in front of the bulldog than drive the pete with a paccar. Bulldog or no bulldog a mack would leave the pete in the dust.
  6. mikey747
    mikey747 Light Load Member
    60
    20
    May 13, 2016
    Thanks for the reply good to hear from drivers that have the engine.
  7. mikey747
    60
    20
    May 13, 2016
    great advice thanks
  8. mikey747
    60
    20
    May 13, 2016
    Did you drive a Mack with the MP-8 if so can you tell me if it was dependable. A lot of Macks with MP-8’s are hitting the market and they are cheep especially with the automatic trans.
  9. mikey747
    60
    20
    May 13, 2016
    Thanks a lot I did not think to check youtube. The DD15 has some fans on this post, and that helps a lot.
    PE_T Thanks this.
  10. mikey747
    60
    20
    May 13, 2016
    Thank you for the reply, good advice from someone who owns one.
  11. mikey747
    60
    20
    May 13, 2016
    Most of my loads may be light with the occasional load putting the truck in the 78000 lbs range. Does running light hurt a 15 liter engine?
