Need Engine Advice
Discussion in 'Ask An Owner Operator' started by mikey747, Jun 10, 2020.
  1. mikey747
    mikey747 Light Load Member
    60
    20
    May 13, 2016
    Thanks for the input, love the disclaimer lol.
    Stringb8n Thanks this.
  3. mikey747
    60
    20
    May 13, 2016
    Thanks for the input, that is a lot of great advice and experience to call from it is appreciated
  4. AModelCat
    164,990
    Thats the thing with the US, they have some of the lightest gross weights on 5 axles in the world. I think a 5 axle setup in Canada is good for about 87,000. Out in the prairies its flat and a 13L will handle that just fine. Then you get out into the mountains with a super b at around 140,000 you need that big bore engine to get around.
    daf105paccar and mikey747 Thank this.
  5. mikey747
    60
    20
    May 13, 2016
    Thanks for the input, I didn’t know that the engine heat could affect the after treatment like that. Now one truck I’m considering has the 15 liter Cummings and the After treatment has been deleted would that be ok or just ignore it and look at the 12L and 13L?
  6. AModelCat
    164,990
    I can't give much insight into the delete. Apparently it can be a nightmare to find somebody willing to work on a deleted truck, so that'd be a risk you'd need to weigh.
    mikey747 and PE_T Thank this.
  7. daf105paccar
    6,564
    7,294
    Apr 15, 2012
    There are horror stories on TTR about badly deleted trucks.
  8. AModelCat
    164,990
    Basically when the aftertreatment does a regen, its just heating the DPF up in order to catalyze the soot off. If the engine is working hard, its already making lots of heat.
    mikey747, PE_T and daf105paccar Thank this.
  9. mikey747
    60
    20
    May 13, 2016
    To all the Drivers out there who took the time to give me advice, I would like to say thanks. I’ve decided to go with a Freightliner with the DD15 and a 13 Spd Trans. I got a lot of good advice from my local Freightliner dealer Service Tech’s and I’m now in the process of finding my next Truck. Thanks again.
    Accidental Trucker, Chris M. and PE_T Thank this.
  10. Newbieboy
    Newbieboy Light Load Member
    91
    25
    Apr 3, 2019
    Were you having any problem with injectors why did you replace? Thanks
  11. danny23tx
    danny23tx Road Train Member
    1,494
    2,324
    Feb 16, 2016
    Austin,Tx
    At roughly 500k 2 injectors were operating below spec and truck was running funny , so I had them all changed out for new ones .
