Need help 95 wca/wia engine codes
Discussion in 'Volvo Forum' started by Endlessdvr, Dec 16, 2018.
  1. Endlessdvr
    Endlessdvr Bobtail Member
    9
    5
    Oct 6, 2015
    Hey guys,
    Need some help, got a WCA with a N14 cummins, cutting off randomly but mostly when taking off or coming to a stop. I think it might me electrical but I am getting some flash codes out of the diagnostics button but don't know what it means.
    So I need to see if anyone knows or has the codes for that year model. I got code 9
    Thanks in advance.
    Dan.
  3. 062
    062 Road Train Member
    6,329
    33,969
    Oct 20, 2013
    Are you sure it’s 9?
    Not something like 1 flash pause 5 pause 3?
    Maybe @BoxCarKidd is around,I think he used to work on those trucks.
    BoxCarKidd Thanks this.
  4. Endlessdvr
    9
    5
    Oct 6, 2015
    I will be heading to the truck un a little.. will confirm the number of flashes.
    Thanks.
  5. BoxCarKidd
    BoxCarKidd Road Train Member
    4,548
    6,641
    Aug 26, 2014
    I am with 062 about those flash codes. That is a Cummins thing. Sometimes you just need a scanner.
    Problems I recall are a battery cable left off. I thank they all had 2 + and 2 - cables from the battery pack. They went to the starter ground and solenoid positive. Insulation worn through a positive cable on the frame or PTO?
    The truck main power feeds connected to positive solenoid terminal. Botched up terminal ends on those from a previous starter replacement. Ground could do the same.
    Loose grounds in the cab. If I have not confused them with another model there is a gob of white ground wires on a screw under the dash panel on each side. That would be near the outside bottom corner of each windshield.
    More direct to your problem check the ECM power and ground wires at the batteries. Are the batteries moving around?
    We had one with a Cat doing stuff like that. It ran regional but finally shut down coming to a light 5 miles from the shop. Volt gauge still worked and the starter would spin the engine over. Test light would light between engine and frame. It had no ground wire between starter ground stud, block and or frame. Seems it ran over 400,000 miles grounding through engine mount bushing bolts and or driveline.
    062 and AModelCat Thank this.
