Need Help DEF Consumption
Discussion in 'International Forum' started by mtlmike, Mar 17, 2023.
  1. mtlmike
    mtlmike Bobtail Member
    Hello All,
    I've noticed the last 2-3 days that my def usage has gone up drastically. Can anyone please point to me to the possible issue? or needing to replace the filter?
    2016 International 4400
    Any help is greatly appreciated
  3. JB7
    JB7 Road Train Member
    1,026
    1,812
    Dec 13, 2022
    Laurel, MD
    Engine, mileage, any codes or lights on? What was the usage before, what is it now? Usage should be about 3%, so 3 gallons of DEF for every 100 gallons of fuel. Heavy loads and temp can affect usage. Look for fluid leaks; crystals around the SCR or doser; cracks in the SCR near the doser; exhaust leaks from the turbo to the SCR; remove and inspect the doser.
    mtlmike Thanks this.
  4. uncleal13
    uncleal13 Road Train Member
    3,797
    6,299
    Apr 9, 2009
    Humboldt, Sk
    It’s consumption is directly related to fuel usage. Any bad weather lately, strong winds?
  5. NH Guy
    NH Guy Medium Load Member
    610
    2,079
    Feb 26, 2023
    Probably too obvious, but could there be a leak in the line?
  6. Heavyd
    Heavyd Road Train Member
    7,826
    6,276
    Feb 4, 2009
    Check for leaks, it will form a bit ball of dried up white colour crystals. If not, it needs to be flow tested to make sure it isn't stuck open.
