Need help!! Freightliner with Cat 3406e got me stumped
Discussion in 'Trucks [ Eighteen Wheelers ]' started by 2tonchevy, Sep 6, 2022.
  1. 2tonchevy
    2tonchevy Bobtail Member
    38
    12
    Sep 12, 2017
    Hopefully somebody here can help me:
    1998 cat 1lw 3406e in freightliner classic
    No start
    Ecm will not power up
    power supply and grounds have been verfied and load tested (keyed hot, constant hot, and ground)
    Ecm has been bench tested and ran on boyd caterpillar dyno in corbin ky and is good
    Check engine and engine stop lights do not come on on dash but i have confirmed that they do work (bulbs not bad and wires are good)
    What am i missing???
  3. Big Road Skateboard
    7,202
    40,929
    May 2, 2021
    @2tonchevy You say load tested. Have you checked ECM power and ground while it's plugged in key on, or only after removing the harness?
  4. 2tonchevy
    38
    12
    Sep 12, 2017
    Yes
    i tried a good spare ecm and had mine checked at CAT.
  5. 2tonchevy
    38
    12
    Sep 12, 2017
    I load tested the hots and ground for ecm power supply to 10 amps.
  6. Big Road Skateboard
    7,202
    40,929
    May 2, 2021
    Yes to which one? Did you verify ECM power and ground with the ECM plugged in?
  7. 2tonchevy
    38
    12
    Sep 12, 2017
    If i understood him...The tech at cat told me i had to have two 5 volt datalink inputs to the ecm in order for it to power up. I had never heard this. But i do not have ANY voltage or grounds on the datalink pins on the harness coming from the truck.
  8. 2tonchevy
    38
    12
    Sep 12, 2017
  9. Big Road Skateboard
    7,202
    40,929
    May 2, 2021
    Do you have sensor voltage supply?
  10. Big Road Skateboard
    7,202
    40,929
    May 2, 2021
    Have ypu checked specifically for an ignition power feed? Not constant battery supply
  11. 2tonchevy
    38
    12
    Sep 12, 2017
    I have not pinned the sensor side of the ecm. Just been focusing on getting it to turn on lol the guys at cat that ran my ecm on their dyno instructed that i only needed pins 4, 5 and 6 verfied and datalink voltage to turn on the ecm.
    I admit that i do not know much about how this ecm works or how the "datalink" interacts witj the ecm. But im trying lol
    Oxbow Thanks this.
