Need help identifying a part DD15
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by LoneRanger, Jan 21, 2022.
  1. LoneRanger
    LoneRanger Road Train Member
    3,695
    9,607
    Jun 3, 2018
    2013 DD15 need help identifying this part. What is it called?
  3. Goodysnap
    Goodysnap Road Train Member
    3,792
    9,232
    Jul 12, 2017
    As you know I’m no Detroit guy. By the location and appearance I would say that is your 7th injector or also known as the DPF fuel doser/ injector.
    LoneRanger Thanks this.
  4. LoneRanger
    3,695
    9,607
    Jun 3, 2018
    When we spoke on you doing EGR cleaning, does it also clean this location?
  5. msh
    msh Light Load Member
    159
    110
    Jul 18, 2021
    Los Angeles, CA
    That injector must be removed and the hole must be cleaned every 6 months... otherwise regen temp is going to be low and there will be high *fuel pressure in hydrocarbon injection line* code( sorry i forgot the numeric code)...
  6. Animosus
    Animosus Heavy Load Member
    736
    2,936
    Dec 7, 2015
    SE Wyoming
    The detroit manual will call it a "Fuel Doser Injector Valve" or "Hydrocarbon Doser Block" aka 7th Injector.
    msh and LoneRanger Thank this.
  7. LoneRanger
    3,695
    9,607
    Jun 3, 2018
    no codes yet, but that’s the next cleaning I’ll be doing.
    do you happen to know if the chunks of carbon fall into the exhaust pipe it’s going to be a problem? Or will a regen fix it?
  8. msh
    159
    110
    Jul 18, 2021
    Los Angeles, CA
    no problem. it will go to doc face area and eventually will be burned off
  9. LoneRanger
    3,695
    9,607
    Jun 3, 2018
    Any special tools to remove the injector? And jam a bolt down to clean it like in a YouTube video I’ve seen. Or should I remove the whole assembly to clean it properly?
  10. Antinomian
    Antinomian Road Train Member
    2,196
    3,492
    Feb 17, 2013
    Regen will fix it. I use an .40 cal gun barrel brush to clean out the orifice. A new doser is about $185. I've always just replaced mine when necessary. SPN 3556 is the code you get when a regen fails because it can't generate enough heat. A clogged doser causes the fuel to stream out instead of spray as a fog.
    LoneRanger and msh Thank this.
  11. msh
    159
    110
    Jul 18, 2021
    Los Angeles, CA
    no special tools needed. 10mm socket with extension 12 mm and 14mm wrenches and gun brush..
