need help identifying cables
Discussion in 'Trucking Electronics, Gadgets and Software Forum' started by WREN, Oct 5, 2019.
  1. WREN
    WREN Medium Load Member
    378
    239
    Jul 17, 2017
    Florida panhandle
    Ok, just picked up a new to me 2014 KW T680. This cable was ran up the inside of the sleeper from under the bunk. I dont think its factory how it was ran but hell I dont know.
    jammer910Z Thanks this.
  3. x1Heavy
    x1Heavy Road Train Member
    34,017
    42,137
    Mar 5, 2016
    White County, Arkansas
    The round has a ethernet cable in it probably for qualcomm.
    The other two are probably video card signal cables to a monitor. Otherwise known as a DVI type.
  4. NantahalaJoe
    NantahalaJoe Bobtail Member
    5
    Jul 10, 2019
    Can you show us the end/tip of the wide cables? As already mentioned, it is probably a DVI and VGA cable. But seeing the pins is important here.
  5. MPBara
    MPBara Bobtail Member
    8
    7
    Nov 4, 2017
    The 3 cables look like the required connections for the qualcom black box and antenna
  6. Carlinho
    Carlinho Bobtail Member
    28
    39
    Mar 2, 2018
    Harker Heights, Texas
    Old qualcomm set up. Some kind of electronic module under bunk and from there to the top outside the sleeper.
