Need help! Need the truck this week.
Discussion in 'Freightliner Forum' started by dajain, Jul 21, 2023.
  1. dajain
    dajain Light Load Member
    111
    135
    Apr 16, 2022
    The truck is a 1999 FLD120 with a Cummins N-14 Celect+.
    Brief history:
    PARTS~
    New injectors
    New oil pump with cooler bypass
    New Oil cooler
    New main bearings
    EMC rebuild (Last week)
    New throttle pedal sensor
    New Alternator
    New batteries
    And many other things not really related I don't think.
    Excellent multi point grounds established on various points on truck frame and engine
    Problems~
    Injectors 1-6 codes & 5 Volt power supply fault
    -ECM rebuild corrected these codes
    Engine shuts down when throttle goes back to neutral.
    Here is the situation:
    -Got the ECM back this week and got it installed.
    -Was told all codes were cleared with the rebuild so I didn't try to read the codes.
    -100° outside. 65 mph test run with no trailer
    -26 miles, the problem starts: Engine stops running when throttle is left off
    -Can restart every time and keep going.
    -Even without clutch usage, the engine stops running when throttle is let off of
    -Cruise control works but if going down a grade, no throttle by cruise control will shut engine off
    -Got to here I was going (66 miles), read codes and got SID 251~power supply, inactive, 41 times (not 5 volt power supply like previous code before ECM rebuild), and erased codes
    -Cleared codes and drove home
    -same scenario the 66 miles back home, Engine stopping while letting off the throttle
    _Got home, read the codes and ZERO codes were present.
    What should I check from here?
    Throttle position sensor?
    Is there an external power supply I'm not aware of?
    What would be causing an engine stop if I let off the throttle?
    Any help is greatly appreciated.
  3. dajain
    111
    135
    Apr 16, 2022
    Is there an external power supply I'm not aware of for the ECM?
  4. dajain
    111
    135
    Apr 16, 2022
    Just wondering if a additional power wire (switched of course) to the fuel solenoid would help correct this shut down situation? Or bypass a low voltage situation while running?
  5. Magoo1968
    Magoo1968 Road Train Member
    2,062
    5,493
    Mar 18, 2021
    St Malo mb
    Call Cummins maybe don’t use dealerships unless they have old school mechanics.
    Bean Jr. Thanks this.
  6. dajain
    111
    135
    Apr 16, 2022
    This issue has been the same for a year now, been from Utah to North Carolina with the truck and none of them can help me for less than $2000.
    If you price all the parts I've put in so far, it's well over 8k.
    I just seem to have a hard time paying $250 an hour for something that can probably be bypassed for $20
    Not really helping with a repair option but thamks!
  7. FLHT
    FLHT Road Train Member
    1,439
    2,585
    Aug 2, 2014
    So you have put 8k into changing parts and squawk about $ 250 shop time.
    The shop time around my area is $90 to $125 an hour.
    Finding someone who knows what they're doing is the hard part.
    ZVar and Magoo1968 Thank this.
  8. dajain
    111
    135
    Apr 16, 2022
    Who says I don't know what I'm doing? o_O:confused::cool:
    Every part I've changed on this truck needed to be changed and I saved thousands of dollars by doing the work myself.
    When I did the injectors, it was running on 3 cylinders. Oil pump? 18 psi of pressure at 1500 rpm. ECM? Injector timing board was throwing faults. Only part I just threw at it was the throttle sensor.
    I just thought that since it was the end of the day, time to come in and have some dinner and relax, I would ask here to see if anyone had any insight before I start diagnosing and tearing into the truck.
    The only thing that I bought and shouldn't have was the truck itself. haha
    But, anyone have some informative comments to where I should start looking for this issue to get it corrected other than just find a shop that knows what they are doing?
    The nearest Cummins dealer is 150 miles away and have never had much luck with them at all. I get the normal "Bring it in and we'll see what we can find", but I will say that when I'm travelling with the truck, Cummins dealerships are 1000% more helpful than Freightliner dealerships.
  9. Big Road Skateboard
    7,209
    40,987
    May 2, 2021
    Does it act like it runs out of fuel, or just dies like you turned the key?
    Bean Jr. and dajain Thank this.
  10. dajain
    111
    135
    Apr 16, 2022
    Shuts off like you turn the key off. Push the clutch in and she fires right back up
    Weird thing is, it doesn't matter if the clutch is used or not while shifting. Let off the throttle and it dies like the key is shut off.
    All my gauges read good and no engine codes.
    It does have a non-OEM fuel solenoid on it but if that was failing, it doesn't make sense that would only happen during shifting and then start right back up.
    If the motor was shutting down on a safety due to RPM change, it should be throwing a code but nothing is stored.
    That's why I'm thinking a jumper to the solenoid would let me know whether its dropping the 12v power and shutting the fuel off.
    If I don't shift or let my foot off the throttle, she'll pull like a train all day long
  11. Steptank
    Steptank Bobtail Member
    7
    18
    Jun 29, 2017
    Your problem sounds similar to what i had with my n14 several years ago. Have you check the cam position sensor? I had to keep my foot on the pedal to keep it running soon as u took foot off pedal the motor shut off. Never displayed a code.
