Need help regarding gear ratio
Discussion in 'Tanker, Bulk and Dump Trucking Forum' started by Ravind3r, Jul 15, 2023.
  1. Bean Jr.
    Bean Jr. Road Train Member
    5,574
    9,936
    Mar 30, 2014
    What kind of weight?
    Oxbow and Ravind3r Thank this.
  3. Ravind3r
    Ravind3r Bobtail Member
    19
    8
    Jul 15, 2023
    Full gross super b, 63,000 kgs
    Oxbow Thanks this.
  4. Big Road Skateboard
    7,202
    40,929
    May 2, 2021
    I would think you'd be fine. Put it in manual mode to control shift point
    Oxbow, Bean Jr. and Ravind3r Thank this.
  5. Star Rider
    Star Rider Road Train Member
    1,797
    18,997
    Sep 23, 2019
    Back in the day we did it with 318 Detroits, just sayin.
    Oxbow, W923, Bean Jr. and 4 others Thank this.
  6. Magoo1968
    Magoo1968 Road Train Member
    2,062
    5,493
    Mar 18, 2021
    St Malo mb
    425 hp used to be a big dog pulling super b you have 1850 ft lb it will do fine . Might not be the fastest on the hill but won’t be the slowest either .. your jakes will be stronger than many other people also ..
  7. Long FLD
    Long FLD Road Train Member
    12,958
    54,388
    Mar 4, 2015
    You can hold the auto in gear and run the rpm’s up if that’s what you’re concerned about. But you’ll basically be asking a standard highway spec truck to go do work that isn’t ideal for it.
    Oxbow and Bean Jr. Thank this.
  8. Cat sdp
    Cat sdp . .
    21,320
    76,354
    Apr 8, 2012
    Orion's Belt
    Kinda interested in what trimac was looking for
  9. RockinChair
    RockinChair Road Train Member
    5,404
    14,551
    Feb 19, 2012
    Lubbock, TX & thereabouts
    That's 138,600 lbs. What are the weight ratings on your suspension, axles, and tires?
    Also, your X15 probably has its HP peak at 1600 RPM or higher. You will need to get above 1350 RPMs to pull the hills but you probably will not be in top gear when you do it. If the ECM will not let you exceed 1350 at all then you'll need to take the truck to the dealership and have them adjust the parameters.
    And I'm not trying to give you a hard time, but if I were you I would've asked Trimac what specs they require for you to lease on, or at least have bought a truck with the same specs as the company truck you were driving.
    lester Thanks this.
  10. W923
    W923 Road Train Member
    1,426
    4,420
    Feb 28, 2022
    A good big cam with 400 stock hp and probably 1250 torque will pull 150k around the hills of West Virginia and the pa turnpike…just not very fast. I do think you will have issues at that rpm with cooling because of low flow from the water pump and also less fan action.
    Bean Jr. Thanks this.
  11. Magoo1968
    2,062
    5,493
    Mar 18, 2021
    St Malo mb
    He won’t be pulling any decent grade in bc in top gear so engine should be at the right rpm on the pulls . Trimac may have plenty of company drivers and just used any excuse not to hire a owner op in that area until work picks up more ..
