Need help regarding gear ratio
Discussion in 'Tanker, Bulk and Dump Trucking Forum' started by Ravind3r, Jul 15, 2023.
  1. Long FLD
    Long FLD Road Train Member
    12,958
    54,394
    Mar 4, 2015
    His X15 probably has a variable speed fan and doesn’t rely on engine rpm for high fan speed to cool it down.
    Oxbow Thanks this.
  3. jbatmick
    jbatmick Road Train Member
    2,200
    2,511
    Dec 1, 2009
    hastings, Fl
    That is what a transmission is for. Just find a lower gear.
    Bean Jr. Thanks this.
  4. Rum
    Rum Bobtail Member
    29
    26
    Feb 22, 2019
    I fondly recall my 2019 Freightliner, powered by the robust Detroit Diesel DD15 engine that I maintained myself. This powerhouse delivered a solid 505 horsepower coupled with an output of 1760 lb-ft. Its rear axle, geared at a ratio of 3.63, was particularly adept at handling demanding hill climbs, providing exceptional pulling power in challenging terrain. Moreover, I had tweaked the speed settings to optimize performance. This allowed the truck to tackle steep gradients at speeds exceeding 70 mph, a feat that left many other company rigs struggling at significantly lower speeds in similar conditions.
  5. gekko1323
    gekko1323 Road Train Member
    1,668
    2,785
    Jul 14, 2018
    Henderson, NV
    What kind of mileage were you getting? Also, what happened to her?
  6. Rum
    Rum Bobtail Member
    29
    26
    Feb 22, 2019
    Most improvement in mpg was addressing overdue maintenance underscoring the direct impact of proper maintenance on fuel efficiency. Going from 5-5.3 mpg loaded to 6-6.5mpg and from 7-9 mpg empty to 9-12 mpg was a significant improvement. Although preventive maintenance might seem more costly upfront, it often results in lower overall costs by avoiding significant repairs down the line.
    I chose to leave the company when they shifted from a salary-based pay structure to compensation per mile. The cpm arrangement failed to adequately compensate for the additional maintenance tasks I was undertaking, and with the new management, it became evident that all drivers would be severely underpaid.
    gekko1323 Thanks this.
  7. Rum
    Rum Bobtail Member
    29
    26
    Feb 22, 2019
    Additionally, it's worth mentioning my experience with the next company, where I operated in the same territory. I was assigned a 2023 Pete with an MX11 engine, 395hp, and 3.08 gears. Despite its newer model, the truck only achieved 4 mpg when loaded and 9-13 mpg when empty. Even minor inclines significantly reduced its speed, and it struggled considerably on grades above 5%, essentially crawling. Right from the start, on its first day straight from the factory, I had to put the truck out of service. These trucks proved to be unreliable, with frequent repairs needed even before reaching 5,000 miles. Combining mountainous terrain with underpowered trucks is a recipe for poor efficiency. The additional strain on the engine in such conditions significantly impacts the truck's ability to maintain efficient fuel consumption.
    Magoo1968 and gekko1323 Thank this.
  8. gekko1323
    1,668
    2,785
    Jul 14, 2018
    Henderson, NV
    Well, that's what the company paid for. 395hp? Really?
    Bean Jr. and Magoo1968 Thank this.
  9. Magoo1968
    Magoo1968 Road Train Member
    2,062
    5,493
    Mar 18, 2021
    St Malo mb
    I bet their brake cost went up as well using a 11 litre in the mountains. 95% of drivers won’t go at a slow speed required to avoid braking.
    AModelCat Thanks this.
