Need help understanding "New" codes in Paccar engine.
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Guntoter, Jul 26, 2015.
  1. Truckers Report Jobs
  2. daf105paccar
    6,564
    7,293
    Apr 15, 2012
    http://www.thetruckersreport.com/tr...s-anyone-witnessed-these-codes-before.303629/
    And this about Cummins engines.
    So why did i post these problems here?
    To show that you will find lemons with all brands,that's why i have allways advised anyone "if you are buying a late model truck,buy it brand spanking new so you have full warranty from the factory.
    In Guntoter's case i'm shure he would have been able to return the truck to Peterbilt by now(had it been a new truck).
    Granted he would have had to buy a new Peterbilt in exchange but at least his lemon would be gone.
  3. rachi
    rachi Road Train Member
    4,246
    5,231
    Feb 25, 2010
    SoCal
  4. Guntoter
    Guntoter Road Train Member
    1,659
    1,521
    Mar 24, 2012
    Phoenix, AZ
    I bought my truck used (24 month old) and no, I could not return it (buyer beware) it was/is completely my fault for not educating myself. I tried to educate myself but the information i got was A LIE. Four months after buying my truck a class action suit was filed in Federal Court. A month after that, the Federal Government launched an investigation into Paccar's business practices (lying to perspective customers), again, completely my fault for trusting a company that my family had been loyal to for 50+ years (never again).
    Daf, I understand your loyalty to the Paccar engine but you have to know that they are not being honest. Thats not the opinion of a few random anonymous posters on a trucking forum, that is the opinion of several highly paid attorneys (they would not accept this case if they didn't think they could win) it is also the opinion of the EPA and at least one Federal Judge. We'll see where this goes but one thing you and others should consider is this, if this is even partially true, Paccar will have destroyed its name in the U.S. forever and will take the once great names of Peterbilt and Kenworth with them. Those names are already destroyed in my book, and I'm sure with the tens of thousands of those who were lied to then abandoned by Paccar. http://www.qulegal.com/15-08-28-17-PACCAR-Amended-Complaint.pdf
  5. Guntoter
    1,659
    1,521
    Mar 24, 2012
    Phoenix, AZ
    Yes, as of Wednesday. Anyone can join, because they included this at the end of the list of complainants.. "
    All Others Similarly Situated"
    mhyn and rachi Thank this.
  6. pushbroom
    pushbroom Road Train Member
    1,780
    7,319
    Sep 1, 2012
    First off, no truck is unfixable, Yes, you can have lemons and trucks that seem to have more issues, but each issue should be able to be fixed. You mentioned in another thread that you were considering removing all the can bus in the dash and reverting to manual gauges. Not only will it not work, it will be a waste of time as that CAN system is not the system that you are having problems with. The CAN codes you are having are part of the aftertreatment harness. THere is nothing wrong with the dash side of the truck. If you are intent at throwing parts at the truck, get them to replaced the OEM engine to firewall harness and the chassis aftertreatment harness. The OEM engine to firewall harness can sometimes have the loom rub through the wires and give issues, The aftertreatment harness gets routed around the cab mounts and under the frame rail and if not sequred correctly will easily rub through. Both can give you intermittent problems like you are facing, I would also check out the fuse bolted to the side of the battery box. Replace the fuse holder and both cable ends, The cable ends can get corrosion into them and visually look okay, but be almost broken on the inside. That fuse powers the engine and aftreatment system.
    daf105paccar Thanks this.
  7. Guntoter
    1,659
    1,521
    Mar 24, 2012
    Phoenix, AZ
    I appreciate your ideas and I don't want to sound like I am discounting them. Anyone who has worked on trucks as long as I (and it sounds like you as well) understands that there is ALWAYS an answer to EVERY problem on a truck. They would not put a truck on the road knowing that there will be problems from day one. That has been true for 100 years, so if a CEL comes on then a wire must have rubbed against something or a pin came loose in the ECM, maybe a hard part failed etc... But this is different, the lawsuit alleges that Paccar knows when they roll the truck off the assembly line that that truck has a defective ATS and ECM... The ONLY reason they would put that truck on a showroom floor anyway is because they know they can not find the issue (and 5 years later they have not). If the manufacturer can't find the problem, how can I find it? If you have completely fixed a Peterbilt with a Paccar engine and had no CEL's PLEASE tell me how you did it, better yet, send your resume' to Paccar because Im sure they would rather pay you a few million to fix this than the hundreds of millions they could be paying in the next few years if this lawsuit has legs.
    mhyn, rachi and javelinjeff Thank this.
  8. pushbroom
    1,780
    7,319
    Sep 1, 2012
    Ecms are a almost fail free device. I have seen many changed for no reason at all. I will agree that Paccar ecm programming has been poor from the start but with each ecm flash, they get better and better.
    I have fixed quite a few Paccars. Some have been easier then others. Some have been trouble free and I know of a couple that are nearing 1 million k. Not saying they are a perfect engine, however they have been very good for us with a few problem childs.
  9. daf105paccar
    6,564
    7,293
    Apr 15, 2012
    Guntoter,i have had issues with my Paccars but the difference is how they handle it.When they wanted my truck for 3 days to work on it,they gave me a demo truck.Days lost 0.That's a big difference to you,right?
