Need help understanding "New" codes in Paccar engine.
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Guntoter, Jul 26, 2015.
  1. Caesar
    Caesar Road Train Member
    4,343
    593
    Jul 29, 2014
    Netherlands
    I've read all 14 pages of this thread, and from the moment I started reading about Guntoter's problems, I almost knew for certain he has an electric problem. A bad connection, a broken wire, water in a connector, name it. When you get all kind of strange errors, it's usually something like that. The problem is that most mechanics don't understand that. They want to fix something mechanical, but there is nothing to fix. What you need is electrician, someone who can identify problems in electric circuits. How many truck shops have such an electrician?
  3. mhyn
    mhyn Road Train Member
    4,255
    4,515
    Dec 29, 2008
    Northridge, CA
    Almost all shops have certified electrcians but nobody could find Guntoter's problems... and Guntoter is not the only operator in USA who lost money and had big headache because of your fancy mx-13...keep searching in this forum and you will see more victims of euro engineered engines.
  4. Caesar
    4,343
    593
    Jul 29, 2014
    Netherlands
    DAF wouldn't be the #1 tractor seller in Europe if these MX engines are bad. It's more likely a matter of bad cabling. The engines are fine. If you use cheap connectors, if you don't protect everything against moisture, you can get these problems.
    Let me give you an example. I had a problem with the electric door locks of my car. The dealer replaced one and told me another one wasn't very good either. Then a few months later more problems, and he said more locks needed to be replaced. I said no way, it is an electric problem, find it. It took them several weeks (I didn't need the car anyway because of an eye problem), and then they found a badly corroded $ 0.10 wire connector.
  5. Ga11ardo
    Ga11ardo Bobtail Member
    4
  6. Ga11ardo
    4
  7. Ga11ardo
    4
    I have these code do you wat it means bpv diag slmp data
  8. Ga11ardo
    4
  9. Bigdawg69
    Bigdawg69 Bobtail Member
    17
    8
    Sep 17, 2014
    Control chassis node. Thats the problem with mine. Just go under and pull the harness off and look in it. Mine was so corroded that 2 pins were corroded right off. One was the pin that controls the windshield washer....oh it is also same pin that controls scr system so wash my windows and then I would get a ton of lights and derate. They finally found it when my exhaust broke under the cab and melted an airline right with all the harness. They had to unplug to get to the airline and that's how they found the problem. Who knew right. Also that node is $1400 bucks on average.
    daf105paccar Thanks this.
  10. Tug Toy
    Tug Toy Road Train Member
    7,118
    74,495
    Jul 4, 2015
    Corn field
    Oh yea! Bring on the self driving trucks! This is just the beginning. We spent 10 years trying to miniaturize a 100 year old automated factory process. Looked easy on paper, mostly off the shelf parts. Spent about $50 millon and a world wide staff. At the end of the day electronics were the hold up. Sensors, glitches, mysterious codes no one could figure out etc, etc. we could make about %50 of them run reliably but %20 finally just had to be scraped. The other %30 were never ending problems. Needless to say there are 4 other companies over the past 10 years trying the same thing but have not even made it to market yet. Making 2 trucks self drive is one thing. Making 4 million is another. The companies that build them will survive and prosper with 0 urgency on the backs of the operators.
    Sorry, rant over.
    magoo68 Thanks this.
  11. Guntoter
    Guntoter Road Train Member
    1,659
    1,521
    Mar 24, 2012
    Phoenix, AZ
    I gave up.. Re-powered with a Cat. You guys can keep that Paccar trash, I'll make money with my 25 year old technology and NEVER buy another Paccar product again.
    Oxbow and mhyn Thank this.
