Need help understanding "New" codes in Paccar engine.
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Guntoter, Jul 26, 2015.
  1. rollin coal
    rollin coal Road Train Member
    13,708
    28,226
    Mar 29, 2008
    TN
    I would agree with magoo68 that you can't get something for nothing.
  3. Cat sdp
    Cat sdp . .
    21,321
    76,359
    Apr 8, 2012
    Orion's Belt
    Freedom......
    91B20H8 and rollin coal Thank this.
  4. Caesar
    Caesar Road Train Member
    4,343
    593
    Jul 29, 2014
    Netherlands
    How often do you have to do this, normally this shouldn't be necessary.
  5. Caesar
    4,343
    593
    Jul 29, 2014
    Netherlands
    So far no answer I'm afraid.
    On a European Paccar engine you get four warning levels, the first three can be resolved passively by making a long trip, the filter will clean itself. Sometimes it is an active regeneration process, and extra fuel is injected to clean the filter. The fourth warning level is more serious, and you will need a dealer to correct the problem.
    Between each warning level are about 10 engine hours.
    Is this different from NA?
  6. Belials
    Belials Light Load Member
    232
    216
    Jun 10, 2014
    I didn't read through the whole thread, but NA MX stages are about the same. Stage 1-3 can be corrected by the driver by fixing the issue (low def, regen, etc). Once it hits stage 4 it has to be dealer corrected.
    Reason for edit: wording is hard
    Caesar and daf105paccar Thank this.
  7. Cat sdp
    Cat sdp . .
    21,321
    76,359
    Apr 8, 2012
    Orion's Belt
    Thought this might interest you....:)
    daf105paccar and rollin coal Thank this.
  8. Caesar
    4,343
    593
    Jul 29, 2014
    Netherlands
    No thanks, I don't want to be a member of the US administration.
    daf105paccar Thanks this.
  9. CREAMCORNt660
    CREAMCORNt660 Bobtail Member
    4
    Jul 23, 2017
    Fault CAN BUS 2 = humidity sensor or EGR valve. The CAN aka computer has 4 things running on the same 2 lines. I replaced the EGR valve first, with no result. Replaced humidity sensor, shut the truck the h*** up. Maybe a little late for you guys but that was my fix. 2013 kenworth t660 Paccar engine.
  10. Sandcan907
    Sandcan907 Bobtail Member
    I have similar trouble
    2012 pacarr MX13
    After many parts were thrown at it by dealership. I replaced the main wire harness.
    It solved many of the issues that just kept coming back even after parts replaced.
    I too agree and will never buy another Paccar product. Truck or engine. Their total lack of support for their faulty products have cost me literally $80,000 in maintenance in just 2 years.
    Paccar has killed my business. I'll repeat myself again here. I'll NEVER BUY ANOTHER PACCAR PRODUCT. NEITHER TRUCK NOR ENGINE.
  11. Caesar
    4,343
    593
    Jul 29, 2014
    Netherlands
    Your unfortunate experiences are an example of what is wrong with many dealers and mechanics. They lack the true understanding of electrics and electronics. Your dealer should have understood that so many problems with a rather new truck are not normal, and a mechanic with a true understanding of electrics would have suspected a wiring problem far earlier. Unfortunately that has nothing to do with a specific brand, it can happen with any truck.
    Belials Thanks this.
