Need help w 07 century on lights
Discussion in 'Freightliner Forum' started by nsxftw, Aug 25, 2014.
  1. nsxftw
    nsxftw Light Load Member
    192
    39
    Dec 2, 2011
    n/a
    When I turned low beam lights on while driving on highway..All the dash lights and utility lights cut off but when I turned high beam on, all the lights come on as normal even if I don't turned headlights on, light and utility lights work.
    It just that every time when I cruised at night w low beam, all the lights on dash and trailer lights cut off.
    Anyone knows what's the problem? If I'm at stop light or go less than 10mph, it works fine w low beam lights
  3. walterjacobo15
    walterjacobo15 Light Load Member
    104
    91
    Aug 23, 2014
    Here and there
    Start by inspecting the wiring from head lamp to the chassis. You need to take zip ties and protector off in order to do so, make sure you replace them after inspection. I've seen problems on this part of my loom due to vibration, it tends to wear jackets off and cause wires to short out.
    nsxftw Thanks this.
  4. Skate-Board
    Skate-Board Road Train Member
    3,801
    3,996
    Aug 9, 2014
    Merrimack, NH
    Get someone to sit in the drivers seat at night then wiggle the wires and see if you can narrow down where the short is.
  5. nsxftw
    192
    39
    Dec 2, 2011
    n/a
    Thank you so much for the tips. I got it fixed. Found out passenger headlight harness was hitting on metal frame and that's why it must be shortened out.
  6. walterjacobo15
    104
    91
    Aug 23, 2014
    Here and there
    Right on man!! I'm glad to be of any help. GL!
    nsxftw Thanks this.
