Need help with 3406E 3 wire fuel temp mod
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Slow302, May 26, 2018.
  1. lwlevens
    lwlevens Medium Load Member
    623
    427
    Feb 9, 2018
    Well I figure how much hp are you really going to get? Is it worth doing? Like someone said cold fuel only.
  3. little cat 500
    2,061
    1,109
    Jan 17, 2010
    Abbottstown PA
    its not worth messing with
  4. Slow302
    Slow302 Medium Load Member
    348
    117
    Jul 12, 2013
    MO
    I installed both. Fuel mod may add power but didnt see better mpg. Boost mod is better throttle response but its smoke show and soot in oil. I got better boost mod with adjustable switch so you can turn it up or down. 0-11psi on top of yours boost
  5. landlord
    landlord Light Load Member
    61
    11
    Jan 14, 2012
    chicago il
    I bought a fuel wire and on cat et it shows the ambient temp. I thought the ecu was supposed to show higher fuel temper not ambient?
    did I buy a faulty one!!!?
  6. Slow302
    348
    117
    Jul 12, 2013
    MO
    I got both from good ebay seller. Fuel mod will show ECU that fuel is at 147F. Its not ambient frmp its fake fuel temp. And works better on winter when fuel is cold all the time. On summer fuel is hot enough by it self
  7. Diesel Dave
    9,756
    33,564
    Jan 20, 2010
    Hesperia, Ca.
    Just get a tune in it. I was gonna do the resistor thingy, I even bought it from radio shack(resistor), then I decided just to get a tuned dropped in(program reflash ECM) it was the best choice I ever made.
    Oxbow Thanks this.
  8. landlord
    61
    11
    Jan 14, 2012
    chicago il
    I just put the 430 pre low nox tune in!!
    Def better than the 410 multitorque.
    Just wondering why the ecu isn't showing the hot fuel? Checked the ohms and it has low 160 at the resistor.
    Any of you pros have some goof fls fts # for the small block
  9. Cattleman84
    Cattleman84 Road Train Member
    10,057
    71,964
    Nov 1, 2017
    The Sticks, Idaho
    If I remwmber correctly putting the correct resistor inline with the fuel temp sensor only gains you about 35 hp while fuel is cold.
  10. landlord
    61
    11
    Jan 14, 2012
    chicago il
    I'm glad you said something I did a dang-on brain fart.
    I DIDNT PUT THE MOD IN series with THE FUEL TEMP SENSOR...stupid me I put it next to my fuel filter housing...
    Stupid me!!
  11. little cat 500
    2,061
    1,109
    Jan 17, 2010
    Abbottstown PA
    Tune it right and forget about this cheap limited trick.
    Diesel Dave and Cattleman84 Thank this.
